Old 12-22-2007, 10:43 AM   #1
1fast71
1fast71's Avatar
Thumbs down need front spring advice
ive been tryin to find the cheapest but not too dangerous way to lower my truck in the front and i was talkin to a guy that had the perfect stance on his truck and he said that for the front her got some springs outta a 3/4 ton truck and cut them he said it worked fine. ive never done any suspention like work so i was wondering if sombody could give me a link on how to remove the front springs and advice would be cool to
Dustin
if its not broke dont fix it
1fast71 is offline   Reply With Quote
Old 12-22-2007, 12:08 PM   #2
Luvlegs
Luvlegs's Avatar
Re: need front spring advice
Make sure to chain em in so they don't fly out and kill you! I know there are alot of guys that say you don't need to but who wants to be the one who got nailed? Make sure you read up on it if for no other reason than the safety aspect. With a little searching in this section, I'm sure you'll find several threads discussing it and the process - maybe in the FAQ section too - look for the link to the organized threads (it's called something like that) - not hard to do, just be safe. Good luck!
"A cat will almost always blink when hit between the eyes with a ball peen hammer"
(you don't always have to state the obvious)
Wear your PPE! You can eat with false teeth but you can't see with a false eye.
1959 Studebaker Silverhawk 350/400
1972 C10 L6 3OTT
2005 F350 - Built - whew!
Luvlegs is offline   Reply With Quote
Old 12-22-2007, 12:41 PM   #3
nightmare
nightmare's Avatar
the cheapest and safest way is to purchase drop springs. board vendors have them. i wouldn't cut springs, as this compromises the integrity of what the spring was designed to do.
Mike
2001 Dakota R/T - Silver CC - 1 of 1671 •360 w/46RE •392 limited slip
1972 Chevy Suburban - Turquoise/Black
1969 Chevy C/10 - Blue LWB •350 w/ 700R4 •3.73 posi •PS PB A/C - SOLD
Using your turn signal is not "giving information to the enemy"
67-72 FAQ
Originally Posted by GMCMAX View Post
My lugnuts require more torque than your honda makes!
nightmare is offline   Reply With Quote
Old 12-22-2007, 01:08 PM   #4
c10crazy
Like a Rock!
c10crazy's Avatar
Can you please explain your last sentence?
69 LWB
Runs great - work in progress
Mess with me and you mess with the whole trailer park!
c10crazy is offline   Reply With Quote
Old 12-22-2007, 01:21 PM   #5
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
Springs are designed to do a specific job for the vehicle into which they are to be installed. If you get a 3/4-ton spring, cut it down to the height you want and install it, you may find that the ride sucks, and that the lowering effect didn't happen. Coil springs, like leaf springs, have a designated spring "rate", or weight capacity. Shorter, heavier springs will take just as much work as correct lowered springs, to install. By the time you buy the used springs, have them altered, then install them, you may find you could have bought 1/2-ton springs designed for your installation for the same money, or even less.
Heating springs changes their capacity. If you start with heavier-duty springs, heat them and cut them, you may end up with a spring that has less capacity than your original spring. It's iffy, at best.
Member Nr. 2770
Old 12-22-2007, 02:23 PM   #6
cdowns
cdowns's Avatar
the thing about takin a front suspension apart is once you alter what you have you need an alignment//me if i go thru the effort it makes no sence to me not to replace balljoints and tyrod ends and other moving suspension parts with 40years of hard use// i havent seen a cheap front spring replacement in many years
if you're lookin for cheap let it be till you can do it right
Old 12-22-2007, 02:29 PM   #7
nightmare
nightmare's Avatar
thanks ChevLoRay, i couldn't have said it better myself.
Mike
67-72 FAQ
Old 12-22-2007, 04:25 PM   #8
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
people have been cutting coils on these trucks since 67. It isn't hard, it isn't unsafe, and it isn't expensive. Junk yard coils shouldn't cost more than 20 bucks.
Popping a ball joint with a jack under the lower arm and slowly releasing the jack will let the spring fall out. It won't be compressed, and the furthest it'll fly, is the 6 inches to the ground.
Old 12-22-2007, 04:30 PM   #9
centsless
sufficiently talented fool
centsless's Avatar
I agree 100%
"it's impossible to be surrounded by idiots when you are part of the circle"
2003 Suburban
2002 Pontiac Montana
1981 Corvette
1966 Impala Convertible
Click here to support the board
centsless is offline   Reply With Quote
Old 12-22-2007, 04:41 PM   #10
jorgensensc
jorgensensc's Avatar
Just for the sake of the oddball fact that maybe the jack lets loose, could we agree to at least put a chain on the spring to the Control arm... For safety sakes... please?
Shawn
1972 C20 Suburban- Big Blue Betty
'56 Chevy Bel Air Sedan- Frame up Restoration
-What would you attempt to achieve if you knew you could not fail?-
-I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door-
R.I.P. EAST SIDE LOW LIFE
jorgensensc is offline   Reply With Quote
Old 12-22-2007, 05:05 PM   #11
Boog
laying low
Boog's Avatar
Justin as you can see there are lots of varying opinions as to the "best and cheapest" methods to drop a vehicle. There are lots of threads pertaining to lowering these trucks. It's one of the more popular mods. If you care anything about maintaining the stock ride then a set of dropped spindles are the way to go. If you just want a couple inches of drop you could cut 3/4 to 1 full round off the coils with a cutting wheel but the ride will be different. You may not like it.
Support the truck with jack stands and only do one side at a time. Be sure to place the floor jack under the control arm before removing the nut on the ball joint. Be safe!
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Old 12-22-2007, 05:14 PM   #12
BP68
BP68's Avatar
I had a buddy with a 71 that didn't sit quite level all around. We slowly and carefully heated the springs until we got the desired height. DISCLAIMER I do not prefer this method and it is not the best way to do it. But it is prob the cheapest. Ride was decent afterward. There is much truth and good advice in the posts above.
However, on my 68 project I purchased the ECE 4/6 drop kit with parts designed to work together and give you a good ride. I got spindles, springs, shocks, adj. pan hard bar, etc.
68 C10 Shortbed Fleetside
06 Chevy Ext Cab Fleetside
03 Grand Prix GTP
My build thread http://67-72chevytrucks.com/vboard/s...d.php?t=269999
BP68 is offline   Reply With Quote
Old 12-22-2007, 05:37 PM   #13
lts70
1970 Daily Driver
lts70's Avatar
Like boog said drop one side down at a time and cut an equal loop off of your existing springs. If you like it great. If you don't like it buy some drop springs from a vendor and swap them out.
I have a buddy with a 72 that has cut springs all the way around with drop spindles. It seems to handle the same as my truck which has drop springs and the same drop spindles. I wish I would have tried cutting my stock spring first and possibly saved some cash.
Good luck figuring out what to do.
It's not truly yours if you didn't build it yourself or if you don't do your own maintenance.
lts70 is offline   Reply With Quote
Old 12-23-2007, 12:57 AM   #14
see ten
WTB this ad
see ten's Avatar
Yep, If I was going to cut some springs I would cut the ones that are already in the truck (they're already paid for). If you aren't happy with how it rides or the stance, then look at buying some drop coils.
see ten is offline   Reply With Quote
Old 12-23-2007, 03:06 PM   #15
Boog
laying low
Boog's Avatar
Somewhere in these many thousands of posts there are some general guidelines as to how much to cut and how much drop to expect. Like in cutting off 1/2 coil, 3/4 coil, 1 full coil and so forth and an approximate amount of drop from each one. It will vary from truck to truck some.
Boog
primer is finer
Old 12-23-2007, 03:34 PM   #16
LONGHAIR
I would cut the original coils, like see ten said. If you like it, you are out nothing but some time. If not, it gains you some time to look into dropped coils. Like Andy said, people have been doing this for years, 'cause it works. Just don't cut more than one coil the first time. If you want to go lower you can try removing 1/4 more, but go slowly.
If you are starting with a 1/2 ton truck, why would your friend suggest lowering by cutting 3/4 ton springs?
LONGHAIR is offline   Reply With Quote
Old 12-23-2007, 03:47 PM   #17
retodd7711
chrome makes it go FASTER!
retodd7711's Avatar
Look in the suspension section of this board.
There are 2-3 different ways to remove springs and all are explained in those threads. The ball joint job, the u-bolt job. Just be careful and know what you're doing before you start unbolting stuff.
She can't cook
and she won't clean.
But she looks good in a skirt
and she brings me beer.
She can stay for now.
EDIT:: But she left me anyway,
So forget her.
1962 GMC Stepside V6 4 speed
My rolling resto thread
http://67-72chevytrucks.com/vboard/s...d.php?t=324226
My old farm truck
http://67-72chevytrucks.com/vboard/s...=1#post3465005
retodd7711 is offline   Reply With Quote
Old 12-28-2007, 01:00 PM   #18
JCA1972
JCA1972's Avatar
Take the springs out and cut a 4x4 to the height you desire, put them in place of the springs. might be a little bouncy thou.
just kidding, back in the day I had a truck that I wanted to lower, my buddys dad got under the truck and heated the springs with a torch and the truck droped at least 2 inches. this would be the quickest and cheapest way if you ask me.
1971 C-10
2004 Yukon:
1998 Honda Accord
2008 Honda Civic
2004 HD V-Rod
http://67-72chevytrucks.com/vboard/s...d.php?t=226458
JCA1972 is offline   Reply With Quote
Old 12-28-2007, 03:07 PM   #19
Longhorn Man
that is generally considered unsafe.
While it's been done millions of time with good results, they are more likely to fail if heated than if cut.
I've personally lowered many cars and S-10s like that and never had one shatter, but I did see one that did shatter once.
Old 12-28-2007, 03:50 PM   #20
corn
I have cut, heated & replaced springs with no problems, but not saying it cant happen. If you cut, cut a full coil so they still fit in the pocket. If you heat, heat them at one end. Im pretty sure that when people have problems heating them its because they heat them in the middle of the spring. Replacing springs is the best, but remember sometimes when you take out old worn springs & install drop springs you might not be happy with the amount of drop...
corn is offline   Reply With Quote
Old 12-28-2007, 03:59 PM   #21
bad6772
Official Site Guitar Shredder
bad6772's Avatar
i agree with others......i have heard all the stories about not heating or cutting....but never seen it....my personal method would be to cut them....but as Corn said if you take out a worn spring, that are sagging anyways..? when you install a drop spring.....it may raise it or lower it a minimal amount from which you started with......
tony
bad6772 is offline   Reply With Quote
Old 12-28-2007, 08:38 PM   #22
EAST SIDE LOW LIFE
EAST SIDE LOW LIFE's Avatar
Cut the spring "NEVER" heat it. I do 1 coil at a time, 2 coils max if coils are old as you probably lost 1/2 at least over the years.
esll.
Tomorrow is for doing today's stuff.
This truck has just the right amount of energy for me!
Author: Warren Lake .... (member)
EAST SIDE LOW LIFE is offline   Reply With Quote
Old 12-28-2007, 09:48 PM   #23
70short
I just finished cutting 1 coil from mine. The realignment shop said I was border line on the alignment. I figure the truck already had close to an inch of sag up front. With the sag and 1 coil removed I am 3" lower up front. The job was a piece of cake. For all you guy's that say cutting your springs will compromise the integrity, I watched a overhaulin were Chip didn't like the way the car sat when they were finished (including new suspension) he had the crew remove the forward springs and remove a coil. My ride isn't any different then before I cut the coil out.
"72" Red CORVETTE 4-speed 350
"70" Chevy Short Bed early stages of resto.
Edel 600 cfm carb
Weiand Stealth Intake
HEI
shorty Headers
4/2 Drop
295 50R 15 TOYO on 10 inch wide corvette rally rims at all 4 corners.
"CHEVY RULES"
70short is offline   Reply With Quote
Old 12-29-2007, 03:03 AM   #24
c10addict
c10addict's Avatar
Wow did this thread spark alot of opinions.... I too have cut many... I have friends who have heated them with success but I would not do it on my own vehicles... Most important to me in this whole thread find a friend who has removed coil springs and have him come over and help the first time you attempt this... Its not rocket science but can be dangerous and there are a few little tricks to making it easy... Be Safe...
68 C10 Shorty TPI,Bagged, and all the good stuff. Classic trucks feature June 06, On the cover of Jegs Christmas Catalog 08
67 C10 Shorty Shop truck project Bagged and Z'd under destruction and getting nowhere fast.
64 C10 Shop Truck/Daily driver, Bagged, Dropmember, SOLD!!!! Gone but not forgotten..
54 GMC under the knife getting a S10 chassis swap and bagged. See my build thread...
07 GMC Sierra 5/7 drop, 22's and 24's Air ride on my mind..
http://67-72chevytrucks.com/vboard/s...d.php?t=339340
See pics of my trucks in my profile
c10addict is offline   Reply With Quote
Old 12-29-2007, 05:29 AM   #25
EAST SIDE LOW LIFE
Cool Re: need front spring advice
When I did mine I cut two coils to get the drop I wanted. I got a computerized alignment, my alignment was perfect. The camber was 1 degree from a stock measurement and this does not hurt handling but actualy improves it. (So the alignment guy say's.) You can hardly notice this when looking at the truck. So considering all things it handles very good and looks great and will cost you zero!
esll.
