question about rear ends
i have a 68 gmc truck with no rear end in it i was wondering if a chevy one would fit or what can i bolt up to it without trouble
IT'S HARD TO MAKE CHICKEN SALAD WHEN YOUR USING CHICKEN S......... 1968 crew cab build (under construction) |
Re: question about rear ends
Is is a coil spring set up? If you were closer I would give you one I have out of my 67.
It`s probably leaf,right?It it was coil I may know why it`s gone.The GMCs had a tough little Dana60 6-lugger that`s the toughest rear you can bolt into the coil-rear trucks.Leaf was standard on GMCs with coils an option.The opposite for Chevys.If you have trailing arms(coil)you can bolt any 67-72 coil rear in.If you have leafs you can bolt any 67-72 rear in.You can use later GM 12-bolts but will need to relocate the spring perches for leaf or coil and provide mounting for the track bar.
Let's get specific---1/2 ton or 3/4?? 2wd or 4x4?? Coil or leaf? You can bolt anything to anything but if you want it to work well, well----what is your truck?
