Old 12-22-2007, 06:38 PM   #1
BarryB
BarryB's Avatar
Rear Differential Question????
I have a 71 coil sprung rear(one legger) in my 68. I found a posi-unit in a 73-up 1/2 ton 2wd truck.
Can I can swap the carriers from the
73-up into my 71 housing and still use my 71 axles.
I am trying to learn has much as I can before I go and make a deal for the rear out of the truck. So any info would be appreciated.
P.S. Both diffs. are 12 bolts.
*We could learn a lot from crayons... Some are sharp; some are pretty;and some are dull. Some have weird names; and all are different colours;but they all have to live in the same box.
* You may be only one person in the world, But you may also be the world to one person.
* Some mistakes are too much fun to only make once.
Two rules in life.
1. Never sweat the small stuff!
2. Everything is small stuff!
BarryB is offline   Reply With Quote
Old 12-23-2007, 01:53 AM   #2
Re: Rear Differential Question????
Later/earlier doesn`t matter.But over 3.73/under 3.73 does.There are two series in carriers and have to be same/same.I have 3.42s (posi) which never came in our years that I`ll swap into my truck`s rear soon,I hope.Mine has 3.08s but need replaced due to damage.
Old 12-23-2007, 03:35 AM   #3
BarryB
BarryB's Avatar
Ok, now lets say the newer one had 3:08 gears, Does that mean I can put in a 3:42 on that carrier without much trouble?
I put 3:73 gears in Nova I had, it originally had a 2:41 gear. I had to put a spacer in between the gear and carrier.
Two rules in life.
