Active Member
![]() Join Date: Dec 2007
69 Front Bumper
I am currently in the process of planning out the restoration of our 69 GMC (restro-mod if you will) and have a couple of questions.
1) on the front bumper- what about going to a bumper with fog lights in it, only convert the fog lights to the front turn signals- thus removing the turn signals from the lower grille? I would think all you would have to do is re-route turn signal wires and change the lens of the fog/now turn signal lights. 2) what are some other good mirrors (like 3rd generation camero) to use? I plan on converting to the single glass door windows (removing the vent window). Thanks Larry |
Old Skool Club
![]() Join Date: Jun 2001
Re: 69 Front Bumper
If you want to use fog lights for turn signals, you'll need to incorporate a relay setup. The bulbs will draw a lot more current than the turn signal switch is designed to handle. There are headlights from Yogi's that also have an LED turnsignal in the bottom of the lamp assembly that will also do what you want to do, and probably save you some money, based on the cost of the bumper, the lights and the relay setup. The lights from Yogi's are less than $200 for the pair, and they use replaceable bulbs.
Member Nr. 2770 '96 GMC Sportside; 4.3/SLT - Daily driven....constantly needs washed. '69 C-10 SWB; 350/TH400 - in limbo The older I get, the better I was. |
Active Member
Re: 69 Front Bumper
ChevLoRay- thanks for the advise. What I was thinking was pulling out the fog light bulb and harness and replacing it with a set up from the turn signals and just extend each wire down to the new location. I will check out Yogi's.
Thanks Larry |
![]() ![]() Join Date: Jul 2002
Re: 69 Front Bumper
You could also just use the 71/72 front bumper that already has the turn signals lights in them.
I like your idea though.
Old member
Re: 69 Front Bumper
How about a set of these babies! Whooooooo! $595.00
![]() http://www.amazon.com/PIAA-System-Cl.../dp/B0002Z9QVW Man these things are expensive to say the least! http://www.suvxccessory.com/piasu-9451.html http://www.autoanything.com/lights/69A2157A0A0.aspx
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
Re: 69 Front Bumper
palf70step is right i believe the 71 72 bumper works and has them already in there look in lmc they have a wide selection.
but if you want the bragging rights of saying you did it yourself id say go for it just tie in longer wires and you should be set. i like the idea |
