Old 12-23-2007, 04:05 AM   #1
crm318
Alright Alright Alright
crm318's Avatar
negative camber after shock replacement
after changing my shocks yesterday, i took it for a drive in town. it drove well and felt alot tighter, however, when i took it on the freeway, it had a vibration after 50 mph and there was a droning sound. i was afraid to take it over 65. i got home and noticed that the passenger side wheel had negative camber as where it didnt before. what might cause this? im thinking about taking that shock back and getting another. the other wheel is fine. what do yall think?
1972 Cheyenne
Chevrolet red and white
357ci, Vortec heads,
GM Performance high rise intake,
Comp 268H .454/.454 218/218 110 LSA
Quadrajet carb, Flowtech headers, 2.25 40 series
HEI, Curve kit, TH 350, 3.07 gears
275/60/15s on 15x8 rallies
crm318 is offline   Reply With Quote
Old 12-23-2007, 04:10 AM   #2
cdowns
cdowns's Avatar
Re: negative camber after shock replacement
i'd jck it up and check that your wheel lugs are tight first then i'd take the shock off and see how it looks without it// then i'd check wheel bearings and balljoints//
Old 12-23-2007, 09:56 AM   #3
crm318
crm318's Avatar
ill give them a look and let you know.
1972 Cheyenne
Old 12-23-2007, 10:15 AM   #4
bdozeraz
bdozeraz's Avatar
The shock should have no effect on the camber. I suspect you have something else going on and it was just a coincidence that it became noticable after the shock change. I would check your wheel bearings and ball joints also after checking the lug nuts.
bdozeraz is offline   Reply With Quote
Old 12-23-2007, 10:54 AM   #5
whatnow123
whatnow123's Avatar
I agree with the above. Don't drive it unitl you find out what the deal is as there is something mechanically wrong.
67 Short Step, 355, 700R 4.11 posi rear, 4/6 drop Discs on all 4 corners.
Build thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=219094
whatnow123 is offline   Reply With Quote
Old 12-23-2007, 05:10 PM   #6
crm318
crm318's Avatar
i changed the wheel bearings about 2 months ago, but i will check them anyways. i have the day off tomorrow, ill give it all a look over.
1972 Cheyenne
Old 12-23-2007, 05:25 PM   #7
jhow66
jhow66's Avatar
Check upper control arm where it bolts to frame. Sounds like you have some shims missing. Check to see if the bolts are tight.
56 Chevy Bel-Air 2dr. HT (purchased new)
71 Chevy Cheyenne SWB PU (502HO)
65 GMC short bed step--work in progress and my gofer
jhow66 is offline   Reply With Quote
