Old 12-23-2007, 02:05 PM   #1
Hoss72
Talking Well It's Mine
Well it is home..... Now that I have it the questions are numerious, I filled it up with gas and when it was full I looked back and there was a 1/4" hose coming out of the top of the tank and it was spewing gas everywhere so I stuffed a screw in it ....I have no idea where it is suppose to go any ideas. I did find out it is a 71 not a 72 is there much difference between the two?
Hoss72 is offline   Reply With Quote
Old 12-23-2007, 02:23 PM   #2
sick69
sick69's Avatar
Re: Well It's Mine
About a year!
Sorry I couldn't help it. The 1/4" line is probably a vent or return line.
71 or 72 doesn't matter that thing is SWEET!!!
Since it's home where are the rest of the pics??????
Frank
70 chevy lwb c10
454/th400 and a 9" rearend
suicide doors, marker light fuel fill, 4" cowl , mini tub
sick69 is offline   Reply With Quote
Old 12-23-2007, 03:25 PM   #3
Hoss72
Re: Well It's Mine
I will take some tomorrow and post them, the intrerior needs some serious work , they guy put Aluminum in the door panels and on the Glove box. I have panels and worked on them today . I have to fab up some sort of steps or something it is a biggo pain to get into. It is a work in progress.
Old 12-23-2007, 03:59 PM   #4
Jtrux
I'm a poor spectator
Jtrux's Avatar
Re: Well It's Mine
The frame is different on the back, the rear view mirror is mounted on the windshield frame instead of glued to the windshield. The doors have a brace near the vent window in late 71's and 72's so yours may or may not have it. The inside door molding is different in the 71's than the 72's also. That's all I can think of. Oh and 71 is the first year of disk brakes I believe on the front and supposedly the front axle has other things different about it.
2006 Jeep Unlimited IMPACT ORANGE
1993 Chevy 2500 4x4 ExCab LWB 454/NV4500 Tow rig
1977 Ford F100 2x4 LWB 1st truck I owned, still have it!!!
1979 Ford F150 4x4 SWB Built Ford Tough!!!
1971 Chevy Blazer 350 / SM465 / NP205 UNDER CONSTRUCTION Soon to have a LQ4 6.0!!!
Jtrux is offline   Reply With Quote
Old 12-23-2007, 04:35 PM   #5
Hoss72
Re: Well It's Mine
Thanks Jtrux Have a Good Christmas
Old 12-23-2007, 05:14 PM   #6
bouncytruck
SKINNY TIRES RULE!
bouncytruck's Avatar
Re: Well It's Mine
there were minor differences in the grill , I believe it was just in the way they painted it(not an issue with your custom tube grill). All 72's came with front disc brakes, but it was an option in '71. The gas filler tube is a different size on '72s than the rest. Other than that (and what JTRUX stated, it was mostly cosmetic subtleties.
I agree, the fuel line was probably a vent line. You probably got a siphoning effect going on once the fuel pump started pulling the gas.
Nice looking truck. Can't wait to see more pictures.
bouncytruck 1972 K5
The Hauler 1994 K1500 Suburban
The Daily2010 Kia Soul
Wife's Ride2014 Fiat 500L
bouncytruck is offline   Reply With Quote
Old 12-23-2007, 06:24 PM   #7
Jtrux
Jtrux's Avatar
Re: Well It's Mine
You too.
Old 12-23-2007, 06:45 PM   #8
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Re: Well It's Mine
Glad to see you were able to pick up that sweet Blazer! Can't wait to see more pics of that thing.
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 12-24-2007, 02:36 AM   #9
vtblazer
vtblazer's Avatar
Re: Well It's Mine
vtblazer is offline   Reply With Quote
Old 12-24-2007, 05:37 AM   #10
Hoss72
Re: Well It's Mine
Here is some photos I took this morning.
Old 12-24-2007, 06:04 AM   #11
BLUE THUNDER
BLUE THUNDER's Avatar
Re: Well It's Mine
Dude I'm dying to check it out. On a day like today you should roll up the sides on the soft top and cruise. I'm getting ready to do an engine swap today, so if you're on the n.w. side stop by. 269-8322. Later, Mario.
BLUE THUNDER is offline   Reply With Quote
Old 12-24-2007, 07:02 AM   #12
sick69
sick69's Avatar
Re: Well It's Mine
The aluminum diamond plate doesn't look that bad on a lifted 4x4. I have to agree if you don't have anything else pressing to do roll the top up and cruise it abit. Anyway that is a great looking blazer hope you enjoy it.
Merry Christmas!
Frank
70 chevy lwb c10
Old 12-24-2007, 11:25 AM   #13
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Re: Well It's Mine
Sweet ride you ended up getting..
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 12-29-2007, 07:12 AM   #14
bigrey6306
bigrey6306's Avatar
Re: Well It's Mine
Thats nice, looks purtty
71' K5 Blazer
6 in lift
36x14.50 Mud Grips
Crate 350 with headers
Needs a paint job!
bigrey6306 is offline   Reply With Quote
Old 12-29-2007, 07:47 AM   #15
MiniD
Re: Well It's Mine
The hose is most likely your vent hose. There should be one on each side of the tank. If the other one is plugged, and you've added a screw to that one, you might end up pulling a vacuum on your tank as the fuel is pumped out. If you end up having difficulty starting it, try pulling off the gas cap.
That hose should tee in with the hose from the other side and go up to your charcoal filter located by your battery tray (If you're thinking about making it normal). I'm kinda suprised it's a 1/4" hose though. I think mine is 3/8".
MiniD is offline   Reply With Quote
Old 12-29-2007, 07:49 AM   #16
MiniD
Re: Well It's Mine
It just occured to me... does that have a fuel pump in the tank? I see you're running fuel injection. If that's the case, you want to really make sure you have an open vent line. Bad things can happen.
Old 12-29-2007, 08:09 AM   #17
1969k10stepside
Re: Well It's Mine
Disc brakes came stock on the front of all 71s,they weren't optioned with them and have came stock with front discs since.Yes the front axle is a little different but only because of the disc brakes being added.Only the outer stuff like the knuckles,etc are different.The grill has a different paint scheme,mirror is on the windshield frame instead of windshield like 72s,and the back of the frame doesn't come down like the 72s and doesn't have the notch in the tub for where the frame comes down..Door panels and doors are different.Double wall top was only available and won't have the holes in the tub for both styles..
Sweet blazer.I'm glad you got it.
1969k10stepside is offline   Reply With Quote
Old 12-29-2007, 10:19 AM   #18
streetstar
streetstar's Avatar
Re: Well It's Mine
sweet blazer dude --- i dont have one of this vintage yet, but only because i havent liquidated any of my other projects ---
having a blazer like this is on my "must have" list before i die -- But for me , i will just cruise my '88 and keep saving.
I have mixed emotions on the diamond plate --- in a way, its cool, but in another way, it looks like a truck stop nightmare -- The rest looks kick - in the pics
Are you retired too?
Nonsense! I'm in my prime
streetstar is offline   Reply With Quote
Old 12-29-2007, 11:56 AM   #19
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
Re: Well It's Mine
Owner/Op: "TN Classic Transport Carriers"
The Toy: "Square Vette" 72 Hybrid Blazer
Toy Barn: "LuvShack" 40 x 60 x 20 Shop
Tow Piggy:"Maddy" 88 Silverado 3500
Hauler: "Feathers" 14 Aluma 8218T
LUV2XCLR8 is offline   Reply With Quote
Old 12-29-2007, 12:56 PM   #20
vtblazer
vtblazer's Avatar
Re: Well It's Mine
FI should have a closed loop, right?
Don't believe there should be an open vent line if running FI.
Old 12-29-2007, 05:58 PM   #21
Hoss72
Re: Well It's Mine
Thanks for the information I will check it out tomorrow. You guys are so full of information ,....Thanks
Old 12-29-2007, 06:57 PM   #22
red71cheyenne
Back in the sticks
red71cheyenne's Avatar
Re: Well It's Mine
Thats right on the FI. Once its running the fuel that is unused is being ran back into the tank, and if you have an open vent thats not well above the level of the tank, it'll push fuel out. Your overflow tube in the filler neck will work for this, so if you just plug the rest of the vents, you should be ok. Thats how I am running the Blazer tank on the TPI in my 71.
Nice looking Blazer and Congrats!!
1971 Cheyenne C-10 w/700R4 and Tuned Port Injection
1969 K5 Blazer w/Tuned Port
2010 2SS/RS Flaming Orange Camaro
2011 K1500 Suburban
2014 K1500 Pickup
2008 Nissan Altima? The wifes' hoopty
red71cheyenne is offline   Reply With Quote
