Well, I just picked up my Christmas gift to my self.....
A you can probably tell from the following write up, I do not know much about engines other than I like them to run. Anyway, I am trying to do a very correct restoration and I was dead set on using the original 402, but my mechanic (Brian Teal) finally talked me into letting him do a 454( I will just hold on to the original block).
So when someone pops the hood it will look like a stock BB down to the firewall markings and frame markings ect. The only major noticeable difference ( I hope ) will be the GM cast high-rise Holly intake and carburetor. The good stuff will be on inside. The block was bored .60 over so I guess it will be a 468ci. It has closed chambered heads, forged flat top pistons, L-88 valves, cam, ect. Like I said, I don’t know much about engines or how many Ponies it will put out, but I know it will run like a scalded ape and still look stock enough to keep me happy . My biggest concern is that the stock air breather will fit on a Holly carb. I don’t have the carb yet, so I cant test it for sure yet but was assured that it would. DOES ANYBODY KNOW FOR SURE IF IT WILL FIT? Anyway, I cant wait to get it mounted on the frame along with the transmission and drive shaft. Then I won’t like too much to have the rolling chassis finished …………….…Jason
72 Cheyenne Super 80 Silverado Blazer 2wd |
Re: Well, I just picked up my Christmas gift to my self.....
i was hoping you were gonna say you were actually looking for a 454...cuz i have one just built with 14,000 miles by a guy that actually worked for nascar...oh well...hope everything works out for ya...sounds like a hot dog!
R.I.P. Killer 71 10/26/07 |
![]() Join Date: Apr 2005
Got pics? That might look pretty cool in the 52.........
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
Recovering 67-72 Addict
![]() Join Date: Oct 2000
Should not be any problem if you use the factory spacer.
68 Short Fleet 4x4; 427; BTO Level 3 700R4; NP205; Dana 60 front and rear; 4" lift with 35's; Disc brakes; AGR variable ratio steering; factory bucket seats; factory tach and tilt. "Friends call me cruzer cuz I like fast cars and fast women" |
Am no expert on factory air cleaners, but I am definitely a proponent of 454's in Chevy pickups.
I just replaced a non-original 66 396 in my 69 short fleet with a 454. It's got a Comp Magnum cam, TRW slugs, Edelbrock Heads and Intake and a Holley Carb. Should be in the 450HP+ arena and 500+lf ft of torque. I love the combo. Plenty of grunt for that "push you back into your seat" feeling I enjoy so much. Hope'e you're just as happy with your decision to upgrade to the 468. Keeping the original engine around for a numbers matching swap-out, should you ever decide to go that way, is a good thing as well. Congrats.
69 C-10 SWB Fleetside 454/TH400 (For Sale) http://67-72chevytrucks.com/vboard/c...ct=1299&cat=12 70 El Camino 454 TH700 29 Model A 4-DR Sedan Deluxe |
