Old 12-23-2007, 04:31 PM   #1
first truck
first truck's Avatar
I need power conversion info
I have a 66 C-20 with power nothing. I know I can buy aftermarket boosters and upgrade the brakes simply, But the steering I would like to go with a GM product. So what yrs and models can I use? Do I need to change the suspension? can I use that donar suspension? is it as simple as taking apart the column and adding the unit? I can weld, cut , basically fabricate parts to fit , but what would be closest to what I need.?
first truck is offline   Reply With Quote
Old 12-23-2007, 05:57 PM   #2
PrerunnerRob
PrerunnerRob's Avatar
Re: I need power conversion info
http://67-72chevytrucks.com/vboard/s....php?p=1974067
Hope this helps out.
PrerunnerRob is offline   Reply With Quote
Old 12-29-2007, 03:45 PM   #3
first truck
That helps some , but I really need to know is "what doner trucks are good for this"? 70-72 . Its alot cheaper to grab one from the bone yard[ even 2 if needed] Than buy it new. I'm a cheap *#%&. And just want to pull the boat around with this. I'll use this to tool around with
http://i151.photobucket.com/albums/s...camaro2001.jpg
Old 12-30-2007, 08:08 AM   #4
04Xrider
Registered thread killer
04Xrider's Avatar
I believe you can use anything from 67-83, and then the later ones use a o ring seal instead of a compression seal, my setup is from a 87, with the exception of the bracket. The one thing to keep in mind will be the power steering bracket. If you have a long nose or short nose water pump, you will need the right bracket to work with it. I bought a used setup from a salvage, and used them for cores at auto zone, but only after I found that the gearbox was junk. I also used a double ujoint at the end of the steering shaft because the rez kit pushes the box out of alignment with the steering shaft, and I did not like that.
!966 stepside, 350 SB, ZZ-4 roller, Crane roller rockers, 0.030 flat tops, airgap intake, 750 Holley, stainless steel headers, edelbrock SDT mufflers, Mark 8 elec fan, 700R-4, column shift
04Xrider is offline   Reply With Quote
Old 12-30-2007, 01:20 PM   #5
first truck
Thats great to know that so many years are compatable. I'm so used to doing projects that only except 2 or 3 other yrs. Thanks for the info guys
