yes, i do
tranny swap
so i just acquired an 81 gmc sierra grande to swap the motor into my 72 gmc. so my question is is the turbo 400 a direct swap for a turbo 350 short tail?? i plan on using the turbo 400 in my 60 that is sitting on a mid 70's blazer frame
ERROR 404....... SNAPPY COMEBACK NOT FOUND ![]() _______________________________________________________________________________________________ -60 Chevy C10, dead 350/good th350 combo, sitting on a 76 c10 blazer frame, built from 11 different vehicles "the abomination" -07 gmt900 silverado 1500 lt xcab z71, granite blue -81 suzuki gs650g "shelah"- current project -81 kz1000m1 csr "sarge" -next project (just beautification) -07 kawasaki vulcan classic vn900 |
![]() ![]() Join Date: Jul 2002
Re: tranny swap
You'll need to change the end of the drive shaft that feeds into the tranny. T350 used a slip yoke, the T400 uses a different style, bolt on. You'll probably also need to short the drive shaft.
Not sure what is different on the kick down linkages between the two. No it's not a direct bolt in, but very easily do-able.
Bill 1970 Chevy Custom/10 LWB Fleetside 2010 Toyota Tacoma PreRunner SR5 Double Cab - DD Member of Louisiana Classic Truck Club (LCTC) Bill's Gallery Life isn't tied with a bow, but it's still a gift. Live simply. Love generously. Care deeply. Speak kindly. Leave the rest to God! Last edited by Palf70Step; 12-24-2007 at 01:47 AM. |
Re: tranny swap
Not sure about the kickdown switch either. If there is one on the 81 tranny, you'll need to wire it up as well.
69 C-10 SWB Fleetside 454/TH400 (For Sale) http://67-72chevytrucks.com/vboard/c...ct=1299&cat=12 70 El Camino 454 TH700 29 Model A 4-DR Sedan Deluxe |
