ride height
So I have to ask,,,,, How do you set the ride height with air bags? Just by changing the air pressure? When it's aired out does it just sit on the bump stops or can it be adjusted using spacers under the bags for a desired aired out height?
Frank
70 chevy lwb c10 454/th400 and a 9" rearend suicide doors, marker light fuel fill, 4" cowl , mini tub |
Re: ride height
You want air in your bags at ride height... you do not want to sit on bump stops... Yes more pressure raises the truck more.. I set my ride height drivin around a while watchin gauges to where I can turn and still have a decent ride quality.. Remember those pressures for when you hop in it..
