Old 12-24-2007, 12:33 PM   #1
Andy4639
Old member
Andy4639's Avatar
Wiring in 2 relays to the headlight's
OK guy's this ? has been asked I don't know how many times. Who has the best head light wiring with relay's.
I decided to do it myself with $13.00 worth of parts from O-Riley's auto parts.
2 relays
16 count of the yellow spade connector's
1 30amp fuse link holder
Here is what I did.
I figured out from my shop manual that both the low & high beam work off the driver's side light, so I cut the incoming green & grey wires off the connector, then put longer peice of wire to both relay's. This will activate the relay not much load so the wire can be same gauge as factory. I didn't run a heavy gauge wire to the passenger side light but may do it later on. I don't see any reason to but you never know.
Light connector:
Here is the relay's mounted with all the connections done. The one mounted high is for High Beam the lower one is for Low Beam.
I ran a good gauge hot wire with 30 amp fuse holder in line across the radator support to the battery and split off to both relay's. Then ran two grounds for each relay. I then added some length's of wire from each relay back to the connector on the head light. Took me 2 hrs to do it. Hope this helps other's who want to do this upgrade. I used butt connection's or spade connections with black tape on everything and wraped everything in black tape when done.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 12-24-2007, 01:29 PM   #2
VetteVet
Msgt USAF Ret
VetteVet's Avatar
Re: Wiring in 2 relays to the headlight's
Here's a schematic that may help. You should run a heavier wire to both lights. I found another so I included it.
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
Old 12-24-2007, 02:04 PM   #3
cobb_ben
cobb_ben's Avatar
Looks great! Good job! Someday I will do mine. I am surprized the parts were only $13! O'riles must be good. I did the converion on a '76 I had. Makes big diferance!
'69 Chevy C10
400sb-350 crank 400 destroker!!! 377
2.02 dart pro1 alum.heads
msd, holley db
hooker pro-comps-3in exh.
3 spd. saginaw-3.73posi
Flat Bed...want Reg bed...trades?
cobb_ben is offline   Reply With Quote
Old 12-24-2007, 03:27 PM   #4
airdale94
airdale94's Avatar
Looks good! You got part numbers for the relays?
I'm wanting to do this to mine. In the middle of a frontend swap. And auto to manual trans. changeover. I got the frontend swap done befor the snow. But looks like it will be March now for the rest.
VetteVet: Thanks for the diagrams.
airdale94 is offline   Reply With Quote
Old 12-24-2007, 03:32 PM   #5
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
I would mount them a little higher on a driver truck, they'll get splashed with a lot of water there. Imounted mine on the side of the Aux battery tray on the longhorn, haven't done it to the burb yet.
Old 12-25-2007, 03:13 AM   #6
Andy4639
Old member
Andy4639's Avatar
VetteVet,
I may do the other side today. I don't feel like I have to but I may do it anyway. I have the wire already. The only thing is I would have to reduce back down to the orignal size wire or use spade connectors on the light's which I really don't want to do. What did you guy's do about the light connector when using heavier wire? I've been thinking of doing the parking light's and driving lights off of relay's to since I tied the fog lamps into the parking circuit.
airdale94,
The relays were out on the shelf at the store. They were where the fog light kit's are.Both relays have two terminals for the accessaries to hook to so running the other wires wouldn't be a problem I don't think. Part # DF005 good up to 30amp's
Longhorn Man,
I don't think water will be a problem either on them except when I wash it.
Old 12-25-2007, 03:54 AM   #7
68jimmy
68jimmy's Avatar
The whole reason to install relays is to provide a higher amperage to your lights thereby increasing the amount of light. This also keeps the increased amps out of the headlight switch and corresponding wiring.
Sometime ago prior to getting hooked on these trucks I owned a vw jetta gli. I installed a set of european lamp assemblies with H4 bulbs that were rated at 85/80 watts. I did much of the same except that each headlamp utilized two relays, one for high the other for low for a total of four relays. The factory wiring was used from the switch to the relays then from the relays I used 10 guage wiring for both the 12v and ground connections. Seems like overkill but I wanted to be sure that when I had my high beams on I wasn't going to melt any wires.
To calculate the amps your headlights will draw use the following: Amps=watts/volts. So for a 55/45 headlamp using the equation gives us: 55/12=4.58. Together your headlights on high beams will draw approximately 9amps of current. Using that information you can now select the proper gauge wire to use from the relays to your lamps and your grounds...
Good luck!
78 C10 LWB Super Cheyenne
68jimmy is offline   Reply With Quote
Old 12-25-2007, 04:58 AM   #8
Andy4639
Old member
Andy4639's Avatar
Well since we are talking bulbs and such...can some one tell me what kind these are?
I took them out of my daughter's car when I replaced the head light assemblies. This is on the bulb's:
3A HB2
9003
12V
60/55 watt
Will they work in my truck you think? What would be the "+" of using them?
Here is what I have now. Same watt's.
Old 12-25-2007, 04:27 PM   #9
DavesRide
DavesRide's Avatar
Good luck!
I did the same to my Jetta. Very easy job. I could light up road signs for the car in front of me from 500 ft behind them. You definately don't want to play high beam games with someone who has the lights hooked up like this. It takes the load off of the switch (not made for that much current) and lets the relays transfer the voltage directly to the lights. A fast 8 point buck was the only thing that stopped them. He stopped too. He died and my lights shined no more.
R.I.P ESLL Even as the body dies the spirit lives on in the people you touched
DavesRide is offline   Reply With Quote
Old 12-25-2007, 04:32 PM   #10
Andy4639
Old member
Andy4639's Avatar
I haven't even drove it at night yet, but knowing it's got the relay's makes me feel better!
Old 12-27-2007, 08:15 AM   #11
VetteVet
Msgt USAF Ret
VetteVet's Avatar
Originally Posted by Andy4639 View Post
VetteVet,
[B]I may do the other side today. I don't feel like I have to but I may do it anyway. I have the wire already. The only thing is I would have to reduce back down to the orignal size wire or use spade connectors on the light's which I really don't want to do. What did you guy's do about the light
airdale94,
Longhorn Man,
[/B]
Going back and reviewing the schematics and other references, I realized that the heavier wires are needed just to feed the relays. I think you would be fine with the OEM harness from the relays to the lights. It certainly wouldn't hurt to run heavier wires but like you said you would have to rebuild the connectors at the lights.
VetteVet
Old 12-27-2007, 08:21 AM   #12
Andy4639
Old member
Andy4639's Avatar
I haven't done the rest of the wires as of yet. I think it's fine though. Thanks I may do it anyway just for the good feeling.
Old 12-25-2007, 05:31 AM   #13
Sport/Truck
Sierra Grande Club
Sport/Truck's Avatar
Those lamps are an attempt to mimic the HID lamps on European cars….will look out of place on your truck IMO. That type of lamp will be brighter. Get one with a higher wattage like 85W low beam 100 high. The stock ones are 65W low usually.
s/t
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe.
Sport/Truck is offline   Reply With Quote
Old 12-25-2007, 05:42 AM   #14
Andy4639
Old member
Andy4639's Avatar
Sport/Truck,
Thanks,
I was just curious as to what they would look like. I think the tri-bar would effect it greatly.
Old 12-25-2007, 06:05 AM   #15
Sport/Truck
Sierra Grande Club
You can find out what the wattage they are by the pn# and call the local parts store like AutoZone. Not sure what you have now, but it’s could give you something to try if it’s brighter (higher wattage). The blue hue will be a little deceiving though. Hella makes some nice replacement bulbs for your application. And they make them in all kinds of wattage. Will work nicely with your relay mod.
s/t
Old 12-25-2007, 06:15 AM   #16
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
9003's. There are several numbers that have to do with which bulb is correct for whichever application your intent is. They may/may not work in yours. Seems like I recall that Hella's use H4 bulbs. Those you showed are H2B's. I got this info from reading the numbers on the metal base of the bulbs, so I didn't make this data up. My Tundra uses 9006's.
Member Nr. 2770
Old 12-25-2007, 04:13 PM   #17
Andy4639
Old member
Andy4639's Avatar
The light's in the truck now I have no idea what watage they are. I may just have to take them out and put these in to see how they look.
