Old 12-24-2007, 12:50 PM   #1
skokie
skokie's Avatar
Left brake light not working
I just had a bad turn signal switch replaced in my tilt column but now the left brake light is not working. Blinkers and the right brake light are working fine. Any thoughts on what could cause this.? Also the wiring harnesses from the cab to the back lights are new. Which wire in the U harness controls the left rear brake light?
RIP to my son Dylan. 5/17/2002 - 8/18/2018
If you want to know more about rare forms of pediatric cancer or if you want to help fund pediatric cancer research, please check out the website for the non-profit I started.
https://slothforpedcancer.org
68 build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=223234
skokie is offline   Reply With Quote
Old 12-24-2007, 12:53 PM   #2
Andy4639
Old member
Andy4639's Avatar
Re: Left brake light not working
Take the light assembly out of the truck and check the wires for ground with a test light. Does it blink when you turn the signal on? More than likely a ground problem.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 12-24-2007, 12:57 PM   #3
skokie
skokie's Avatar
It does blink when I turn the signal on. Just no brake light.
68 build thread
Old 12-24-2007, 01:37 PM   #4
VetteVet
Msgt USAF Ret
VetteVet's Avatar
Your problem is in the turn signal switch. There is a jumper between the left and right turn signal wires that operates the brake lights when the turn signals are not in use and disconnects the power to the brake light when that turn side is used. The turn lights and brake lights use the same circuits so if the brake lights work or the turn lights work then the bulbs and grounds are good.
Here is a schematic.
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
Old 12-24-2007, 02:40 PM   #5
skokie
skokie's Avatar
I just tried a new brake light switch and got the same thing. I was looking at the diagram and I dont see the jumper you are talking about. Can you highlight it?
68 build thread
Old 12-24-2007, 03:35 PM   #6
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
your problem is probably in the new turn signal switch you installed. Put your foot on the brake (engine off, key in off position) and look over your shoulder at the brake light shining on something, as you are looking over your shoulder, wiggle the surn signal lever, and even put it in left then right signal location. Does the bum brake light come on at all?
Old 12-24-2007, 03:57 PM   #7
68 P.O.S.
Check the switch for a pinched wire inside of the column. That happened to me once.
72 C10 lwb fleetside -stock 350/350 combo
68 P.O.S. is offline   Reply With Quote
Old 12-24-2007, 05:38 PM   #8
VetteVet
Msgt USAF Ret
VetteVet's Avatar
Sorry I can't show you the jumper cause it's built into the turn signal switch. I posted the diagram to show you what color the wires were that went to the turn signals. Left is yellow ans right is dark green. If someone you paid installed the new switch then it's on them to fix it. I'd take it back and say here ya go.
VetteVet
Old 12-24-2007, 05:49 PM   #9
skokie
skokie's Avatar
Vettevet I did pay someone to install the switch.
68 POS I will check it out and see if anything is pinched.
Longhorn Man I will try that out and see if I get anywhere after I check for a pinched wire.
68 build thread
Old 12-25-2007, 03:12 AM   #10
Boog
laying low
Boog's Avatar
Morning Skokie. I don't know what all you have done so far but I suggest using a test light at the rear to first see if there is power getting to the rear and backtrack from there to the front. It can very easily be a bad connection at the U shaped harness connection. If you don't have power down that far from the turn sig switch then it is in the switch or its harness.
Was the turn sig switch replaced to fix this brake lamp problem?
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Old 12-25-2007, 08:58 AM   #11
skokie
skokie's Avatar
Turn signal was replaced due a bad one that came with the column. I checked and I do not have power when the brake light is on but I do have power with the blinker going. I unhooked the U connector and checked all of the wires/connectors and they look good. Looks like it is making a very solid connection when you hook both sides up. I checked inside the column and I dont see any pinched wires etc. Not sure what else there is to check.
68 build thread
Old 12-25-2007, 09:07 AM   #12
Boog
laying low
Boog's Avatar
What about back probing the wires on the turn sig switch side of the U connector? It's possible to have a bad crimp on terminal and even though that's a new sig switch don't mean it's not a bad one. I've bought new parts before that didn't work.
Boog
primer is finer
Old 12-25-2007, 09:11 AM   #13
skokie
skokie's Avatar
I could give that a try. Its the green adn yellow wires correct? If I use my multimeter I show show 12v right?
68 build thread
Old 12-25-2007, 09:24 AM   #14
Boog
laying low
Boog's Avatar
I believe the green and yellow wires are the turn signal wires which you said worked fine. I've looked at that schematic VetteVet posted but my eyes cannot determine the brake light wires's color. I believe it's brown but not 100%. The lamps do operate on 12V. I use a test lamp mostly. Pointed tip with a bulb in the handle and an alligator clip on the wire to ground it. Easy to use, pierce the wire and bulb lights up when there's current.
Boog
primer is finer
Old 12-25-2007, 09:26 AM   #15
skokie
skokie's Avatar
Ill give that a try and see what happens.
68 build thread
Old 12-25-2007, 11:46 AM   #16
68 P.O.S.
Do you have a coil or leaf rear? If you have coils, check to see if the wire is pinched between the spring and the retaining cup. I had this happen as well.
Old 12-25-2007, 11:48 AM   #17
Longhorn Man
as stated before, the green and yellow are brake light AND turn signal wires.
If a wire was pinched any place after the steering colum, the blinker would not work period.
Did you try the watch and wiggle/oporate the signal switch I pointed out before?
Old 12-25-2007, 03:55 PM   #18
skokie
skokie's Avatar
Yep I missed that one I did try the wiggle and no change.
68 build thread
Old 06-20-2008, 12:42 PM   #19
wskibnt
This is a great site! I was having problems with my brake lights and turn signals and thought it was in the sockets and cleaned and still no brake lights.Came to this site by chance and read a few posts about my problem and found that my problem was,you guessed it the blinker switch.Pulled off the wheel and cleaned the contacts and now they are all working.I just want to thank all who post on here because without you I was considering a new wireing harness.
I have a 72 C-10 that I like a whole lot and with this site I will be able to get it back into shape
It was the wiggle test and a mirrow that helped me figure it out
wskibnt is offline   Reply With Quote
