Old 12-24-2007, 02:49 PM   #1
stope4
One Piece Oil Pan Gasket
I have a 402 BB. It's a 1971 engine. What Felpro one piece oil pan gasket works with this? The one at O'Reillys has a thick front seal. I had them pull the four piece and it was very clear that the front and rear seals on the one piece were way thicker than the four piece. Looking for the felpro part number.
stope4 is offline   Reply With Quote
Old 12-24-2007, 03:26 PM   #2
Gray Ghost
Gray Ghost's Avatar
Re: One Piece Oil Pan Gasket
All of them are thicker...my Sbc has one on it right now and the builder said it was a pita to do. You will have to get longer screws to mount the pan.
I would guess the Fel-Pro Website might have that number for you. If not you might have to make a call when they re-open after XMAS.
Kelly
'05 GMC Sierra SLE Z71
Bone stock except for new bed rail caps.
Gray Ghost is offline   Reply With Quote
Old 12-24-2007, 06:59 PM   #3
sodak69c10
sodak69c10's Avatar
i put one pieces on both my small blocks, both felpro's, they came with new bolts. had to drop the pans a long ways to get it in, rather expensive too, but worth it in my opinion less places to leak
,Clint
LOUD PIPES SAVE LIVES
69 C-10 short stepside 406 sbc, 02 YAMAHA WR250F, 07 SUZUKI SV650S, 81 Grand Prix 355 sbc, 81 XT 500 YAMAHA
sodak69c10 is offline   Reply With Quote
Old 12-25-2007, 03:41 AM   #4
mnunn454
mnunn454's Avatar
I used the 4 piece gaskets (plus a dab of silicone in the corners) on my 454 rebuild and it leaked from day 1. Swapped it for a 1-piece and the problem vanished.
I tossed the box so I can't find the P/N, but I got it from AutoZone for just over $40 as I recall.
I'll never use 4-piece gaskets again.
69 C-10 SWB Fleetside 454/TH400 (For Sale)
http://67-72chevytrucks.com/vboard/c...ct=1299&cat=12
70 El Camino 454 TH700
29 Model A 4-DR Sedan Deluxe
mnunn454 is offline   Reply With Quote
Old 12-25-2007, 05:06 AM   #5
stope4
I used the one piece gasket on a small block 10 years ago and never had a leak afterwards. I know the gaskets are thicker, but need a part number for the bb. Don't want to remove the pan only to find out the gasket at the timing chain cover needed to be smaller. I have two part numbers FEL-OS-30061T and FPP1884R. O'Reilly's had the 61-T but didn't show they even sold the 1884R. I compared the 61-T to the four piece gasket. The front at the timing chain cover was about 3/16" to 1/4" thicker. The width was the same.
Old 12-25-2007, 05:38 AM   #6
jaros44sr
jaros44sr's Avatar
This part number came up on the jeg's site
375-1884R Fel pro BBC Check it out... J.
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 12-25-2007, 03:11 PM   #7
grayw0lf
Here's another post to just say "well worth the $$!"
85' CUCV M1009!!! The newest addition!
6.2diesel, Th400, NP208, & only 36k miles!
70' C-10 LWB Fleetside - Looking good these days!
05' Dodge Neon
88' Winner Escape Sport 1750 - 4.3v6
94' Seadoo SP
84' Honda TRX200, bare nekkid. Just a frame & tires.
Always looking for another project or any good deal!
grayw0lf is offline   Reply With Quote
Old 12-25-2007, 03:33 PM   #8
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
I put a one piece on my 454 and it was a p.i.t.a. but its finally on there.
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 12-26-2007, 05:28 AM   #9
1968SWBBigBlock
Active Member
1968SWBBigBlock's Avatar
Buy longer bolts and the PITA will go away, I have changed mine on my truck twice _ other issues not the gasket- and no problems after you go to the longer bolts
1968 SWB
454 + .040, 490HP x 540 FT pounds of Torque 10-1 Kb Forged pistons, recon rods w/ ARP wave loc bolts
781 heads Ported with 2.19/1.88 SSTvalves
Lunati 60204 cam, Micro Trol lifters,
Ported Edelbrock Performer Rpm manifold armor coated, Pertronix Triple Strike Ignition
Holley 770 Street Avenger carb,Headers armor coated
Built by Watson Ruppel Performance in Sarahsville Ohio.
Hardshift Tranny Built Turbo 350,TSI 10" 3000 stall
12 Bolt Eaton Posi 4.10 Richmond Gears moser axles
18.5" x 31" Hoosier Pro Street Radials
ET Classic 5 Wheels - polished
Power Steering, Power Brakes,Disc Brakes,Tach & Gauge Dash, Tilt,Factory Air (gone)
Custom Paint & Body Work
Special thanks to my wife, my son and my money tree
1968SWBBigBlock is offline   Reply With Quote
Old 01-07-2008, 05:33 AM   #10
Gray Ghost
Gray Ghost's Avatar
Mine's leaking like a seive....the guy must have not put it in right. I have to go get this fixed now on a brand new motor!
Kelly
