Old 12-24-2007, 07:09 PM   #1
VROD383
VROD383's Avatar
Vortec questions
what do I need to hook up the computer in my 71 blazer. I just bought the motor it's a 98 5.7. if anyone has some info that be great.
VROD383 is offline   Reply With Quote
Old 12-25-2007, 04:00 AM   #2
clay68c10
clay68c10's Avatar
Re: Vortec questions
No solid info, but I'd get a wiring diagram for the donor and figure out your power and ground situation to get it up and running. Then you can wire in brake light signal, neutral safety switch, VSS, etc if you want or need those inputs.
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO
http://67-72chevytrucks.com/vboard/s...d.php?t=788602
93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday...
05 Jeep Wrangler Unlimited. 3” lift & 6-speed
02 E320 the insurance total “free car”
13 Tahoe LTZ
clay68c10 is offline   Reply With Quote
Old 12-25-2007, 04:30 AM   #3
Huck
Huck's Avatar
Do a search on the net under GM motor upgardes.
One this for sure--before you stick this motor into anything, BE SURE TO REDO the intake manifold gasket. They are notorious for intake gasket failure and it is a real PITA to replace when in the truck. Would also change the heater hose fitting on the intake as it is another know POS.
Othere then those 2 areas, the 5.7 vortec is super--as is the 5.3--Huck
Huck is offline   Reply With Quote
Old 12-25-2007, 04:44 AM   #4
clay68c10
clay68c10's Avatar
I'll second the coolant leaks reseal advice. Super easy with the motor out.
13 Tahoe LTZ
Old 12-25-2007, 04:52 AM   #5
VROD383
VROD383's Avatar
thanks ill check that out
Old 01-12-2009, 08:51 PM   #6
bdas70chevy
bdas70chevy's Avatar
i just did that in my 70 blazer. 5.7 and the computer and 460le trans u need the wire harness and the computer. Unless u buy a harness from painless with computer??
bdas70chevy is offline   Reply With Quote
