who has replaced outriggers?
I've got a pretty decent cab, but the outriggers are trashed. Has anybody replaced them? Are they spot welded on? Just wondering how hard it is to put new ones in.
Old Skool Club
![]() Join Date: Jun 2001
Re: who has replaced outriggers?
I'm gonna play Devils Advocate and send this back to the top.
With that done, I gotta ask, "What are you calling 'outrigger's"?? If you and I were face-to-face, I might say "You not from around here, are ya?" Seriously, Brits have some terms that are "foreign" to us Yanks, like their fenders, boots, hoods and such. So, if that is the case with you, I am going to assume that your outriggers are what we call rocker panels....am I right?
Member Nr. 2770 '96 GMC Sportside; 4.3/SLT - Daily driven....constantly needs washed. '69 C-10 SWB; 350/TH400 - in limbo The older I get, the better I was. |
Its the forward to rear support that runs under the cab. The outriggers or main structural cab braces/supports tie the rear of the cab and the firewall together. The cab supports are welded between the inner rocker back and the "outriggers". I have seen several over the years that were not even welded at the fire wall support....creaky cab??? but easily fixable with a welder.
Josh, I PM'd you |
iwould have guessed he was talking about the front and rear cab supports. if so they are just spot welded to the floor pans and bolted to pillars and inner rockers
common sense isn't so common anymore |
#5 | |
BTW, I just watched ebfabman's videos. I would recommend them to others who do not have any panel replacement experience. Good info! |
Fat Fendered Fleetside
fixed
71 GMC lwb 56 Big window swb 93 GMC Sonoma (dd) radiused fiberglass fender project for 67-72 |
This is all taking place in a garage by the motorway with the bonnet open.
R.I.P ESLL Even as the body dies the spirit lives on in the people you touched |
For the record, I called them outriggers because that is what they are called in the LMC catalog. Didn't know was else to call them?????????
So back to the topic, any advice on replacing these would be appreciated. |
You forgot the facia panel and tonneau. Also the spanner wrench
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim |
I am a Referee of life.
Just do a search on rocker panel replacement or rocker replacement.Rckcrwln just did a great write up on this.There are others on the site.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" Last edited by PanelDeland; 12-25-2007 at 12:14 PM. |
