Old 12-25-2007, 06:20 AM   #1
chevy one
Chevy One
Air Ride for the Rear?
Working on my 67 2WD, LWB with coils,wanting to know what is the easyist and cost efective way to bag the rear. I am lowering the front 2" with drop springs, and want to lower the rear (appox) 3". I still want to be able to tow a 20' travel trailer from time to time. Found these on eBay:
ARNOTT AIR SPRINGS 100 MM STRAIGHT SLEEVE AIR SPRINGS SERIES, PAIR 14" MAXIMUM EXTENSION! THESE ARE CUSTOM AIR SPRINGS DESIGNED FOR VARIOUS APPLICATIONS. PART# 10014VR.
SPECIFICATIONS:
Ride height 10" Max inflated diameter 5.7"
Minimum compressed height 6" Full extension 14" 1/4" NPT air inlet 1500 lbs. @ 100 PSI.
I don't know if the 1500 lb will be enough for towing? Any advice would be great.
CO
Chevy One
67 1/2 Two-on-the-Floor
67 Nova 2Dr Sedan
03 Monte Carlo
I'M NOT OLD, JUST A CLASSIC!!!
chevy one is offline   Reply With Quote
Old 12-25-2007, 09:15 AM   #2
gunkis84
gunkis84's Avatar
Re: Air Ride for the Rear?
call clint up at kp components.. kpcomponents.com tell him what you are after and he'll figure everything up and set you up..866-575-4657
gunkis84 is offline   Reply With Quote
Old 12-25-2007, 09:46 AM   #3
SCOTI
SCOTI's Avatar
Trailing arm trucks should use a double-convoluted bag if it is being used in the factory coil-spring location.
Firestone 2500#/2600# & Slam RE 6's/7's can be used & they bolt-in w/minimal fab work.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 12-25-2007, 10:50 AM   #4
Sinister
Between Trucks...
Sinister's Avatar
Any details or links for this?
Beat it to fit,
Paint it to match...
Sinister is offline   Reply With Quote
Old 12-25-2007, 12:02 PM   #5
SCOTI
SCOTI's Avatar
There's a good installation 'how-to' in the FAQ's section from board member 'MrShelly'. It contains excellent pics which explain much more that typed words.....
I've purchased bags from both AirRide & Suicide Doors.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 01-10-2008, 01:40 PM   #6
Wasted Income
Boosted Member
Wasted Income's Avatar
In MrShelly's install, did he bolt the bag straight to the trailing arm and frame in the rear?
There didn't appear to be a bracket of any sort??
Thanks,
Jeff
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq
1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift
1964 Buick Skylark Twin TURBO 383 LS pro-touring project
2014 VW Passat TDI - Daily Driver
Turbo diesel
2015 Sierra Denali HD Duramax Turbo diesel
2023 Ford Explorer ST - Twin Turbskis
2023 Ford F150 RCSB - Whipple Supercharged
2017 Polaris RZR Turbo
2014 Nor-Tech Center Console - Twin Supercharged Outboards
TURBO ALL THE THINGS!!
Wasted Income is offline   Reply With Quote
Old 01-10-2008, 04:41 PM   #7
SCOTI
SCOTI's Avatar
Thanks,
Jeff
That's how mine are done-- no brackets. If you don't want to hassle w/drilling the required holes in the frame, it's easier to use a bracket on one end (mounting holes + air-fitting).
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 01-10-2008, 06:20 PM   #8
Wasted Income
Boosted Member
I'm not afraid of cutting up my truck, believe me
So Scoti, if you use the double convolute bags in the factory location, with no brackets, how high does the truck sit, aired up, vs, aired down, vs the factory springs?
Is it pretty close to the factory ride height when aired up?
Thanks,
Jeff
Turbo diesel
