12-25-2007, 08:05 AM | #1 |
LWB Club
will 68 doors fit on a 72?
I assume this works but just wanted to make sure.
Sorry for the noobie question. i am learning here.
72 Chevy Custom LWB Last edited by 72ChevyAZ; 12-25-2007 at 08:15 AM. |
12-25-2007, 08:22 AM | #2 |
Re: will 68 doors fit on a 72?
Yes,they interchange.The door panels,and regulators are different between the 2 but the whole door will swap over.
12-25-2007, 08:29 AM | #3 |
The dimple under the went window will be missing from the 68 door and the window and door regulators shafts will be too short for the 72 plastic door panels.
72 Cheyenne Super 80 Silverado Blazer 2wd |
12-25-2007, 08:33 AM | #4 |
LWB Club
So basically, If I do the swap I will have to buy door panels for a 68 and regulators for a 68. Hmmm, I don't know if it is worth it....
72 Chevy Custom LWB |
12-25-2007, 08:38 AM | #5 |
You could swap the 72 regulator into the 68 door so you can still use the 72 door panel. You just won't have the dimple under the wing window.
Frank
70 chevy lwb c10 454/th400 and a 9" rearend suicide doors, marker light fuel fill, 4" cowl , mini tub Last edited by sick69; 12-25-2007 at 08:39 AM. |
12-25-2007, 08:47 AM | #6 |
LWB Club
Ahhh, gotcha. So the final deal is this. No dimple on the 68 doors and I need to buy new regulators anyways so if I buy 72's they will fit in the 68 door and solve the problem of the short shaft and I can still use my panels off of my 72?
72 Chevy Custom LWB Last edited by 72ChevyAZ; 12-25-2007 at 08:48 AM. |
12-25-2007, 08:58 AM | #7 |
Correct! Some guys don't like the dimple on one side but not the other but if you can live with it them your set.
All of the parts inside the doors are as interchangable as the doors themselves. The only issue is the shaft length on the 72s being longer than the other years. Or you could change both doors to the 68s and not have the dimple on either side. With the 72 regulators you can still use the 72 door panels. Frank
70 chevy lwb c10 454/th400 and a 9" rearend suicide doors, marker light fuel fill, 4" cowl , mini tub Last edited by sick69; 12-25-2007 at 09:00 AM. |
12-25-2007, 09:11 AM | #8 |
LWB Club
Thanks for the quick responces everyone.
Sick69- I am looking at both driver and passenger doors from a 68 for about $200.00 In good condition. I need both so it will even things out fine. thanks for the help Jon
12-25-2007, 09:18 AM | #9 |
I have a radical idea!
Make sure you put the door handle studs (the part that the inside door handle goes on) because the shaft on it is longer just like the window regulator is.
BTW, I don't think there are any stupid questions. I'd much rather ask a noobie question than buy a box full of stuff I can't use!
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435 ‘72 C-10 SWB , 350 4bbl, TH350 '69 C-10 SWB , 250 L6, 3 OTT '69 GMC C3500, dump truck, 351 V6, NP435 '84 M1009 CUCV Military Blazer 67 C-30 Turbodiesel build thread http://67-72chevytrucks.com/vboard/s...d.php?t=254096 My trucks http://s226.photobucket.com/albums/d...ediafilter=all Member of the 1-Ton Club! |
12-25-2007, 09:21 AM | #10 | |
LWB Club
i just learned alot!
12-25-2007, 11:51 AM | #11 |
its all about the +6 inches
one other small problem, the panels are not retained to the door the same way. I can't remember off the top of my head, and my door panels are installed on my 72 at the moment, but the 72 has the plastic pop on/pop off retaining studs, while the 67 - 71 have the screws and trim on top.
Still doable, but something els that needs adressed. |
12-25-2007, 11:54 AM | #12 |
What is the dimple hole used for anyway? Explain its use, please.
TJ |
12-25-2007, 12:08 PM | #13 |
LWB Club
I believe the dimple hole/screw is to help hold the door panel together?
Longhorn man- The panels that are on my doors now have the plastic retainers as well as screws on each cornor. Is that what you meant?
12-25-2007, 12:23 PM | #14 |
Right, and the older ones have 4 huge screws in the bottom, and a chrome (or painted) chanel on top that holds the panel on.
12-25-2007, 02:15 PM | #15 |
I forgot about that Anday, but you're right. When I did it, I drilled out the 4 holes in the bottom of the panel, and you have to take the the strip that holds the 67-71 doors that the top. I think there are 4 screws that hold it one, and I had to srill them out too. I can't remember the drioll size, but I just measured the holes in a '72 door. The good thing is that all the screw holes in the 67-71 doors are in the same location as the holes for the push-in clips on the '72 doors.
12-25-2007, 02:54 PM | #16 | |
LWB Club
