Old 12-25-2007, 03:57 PM   #1
5150
C10 Club Tennessee
5150's Avatar
Pics of install of 2600 Bags?
Anybody got pics of the install of the 2600 bags??? I just got mine today and was looking for some pics. MrShelley's FAQ is good but it's the Slams and I was just wanting to see my application installed.
Also will I need a C-Notch?? I don't want to lay it on the ground the front will be 2.5 MacG Spindles and a 2 inch coil.
thanks
Bryan
www.gmtruckshow.com
Project "Andes"-Halen's First Truck
Project: Patina Burb
for he is God’s servant for your good. But if you do wrong, be afraid, for he does not bear the sword in vain. For he is the servant of God, an avenger who carries out God’s wrath on the wrongdoer. Romans 13:4
5150 is offline   Reply With Quote
Old 12-25-2007, 08:34 PM   #2
SCOTI
SCOTI's Avatar
Re: Pics of install of 2600 Bags?
thanks
The bags install the same. I unbolted some Stones & swapped Slams in the same place w/o any issue or extra work.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 12-26-2007, 06:47 AM   #3
gringoloco
A guy with a truck
gringoloco's Avatar
thanks
What Scot said, and the c-notch will depend on your intended ride height. A little rake may keep you from needing it. If you want it to sit level, you might hit the frame. You could also remedy this by using a lowering block, allowing you to have more air in the bag at the same height.
Basically, you're just gonna have to play with it to see if the notch is necessary, but you will be close at that height.
-Chris
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is online now   Reply With Quote
Old 12-26-2007, 07:18 AM   #4
5150
C10 Club Tennessee
5150's Avatar
The bags have the two threaded studs coming out of the top unlike the pics in MrShelley's thread. That's where my confusion lies. Also don't forget I don't have it back from the body shop so I'm going off memory.
My silver truck has a 4.5/6 drop and I don't have a c-notch on it. I like that ride height so as long as it's the same I guess it will be okay. If you think I should go with a one inch lowering block then maybe I should do that as a precaution.
Bryan
www.gmtruckshow.com
Old 12-28-2007, 04:19 AM   #5
BACKYARD88
On the fast track to nowhere..
BACKYARD88's Avatar
The Slams I used have two threaded holes in the top for bolts, instead of the studs like the Firestones. They're still in the same place though. Do remember that unlike the Slams, Firestones expand a little when you air them up so you'll need a little more clearance than with the Slams.
-Mike Owen-
Norwood, Houston, Cecilia, Jackson, Monroe and counting
BACKYARD88 is offline   Reply With Quote
Old 12-28-2007, 04:56 AM   #6
Alvin
Never Done?
Alvin's Avatar
Posts 43 & 44 on this page of my build thread cover the install of Firestone 2600s on the back. My truck is completely bagged, but I also wanted really big tires on the back, so I went with both the c-notch and the lowering blocks so my ride height wouldn't look ridiculous.
I'll try to help if you have any other questions about the install.
Ethel - The Legend Continues...
Ethel has been sold.
Alvin is offline   Reply With Quote
Old 12-28-2007, 10:54 AM   #7
5150
C10 Club Tennessee
5150's Avatar
thanks Adam, still confused though. It will be better when I get it back from the body shop in a couple of weeks.
I'm running 20's all the way around so not sure what problems that will entail. If I have to go with a C-Notch I'll be selling these bags and going back to springs.
Bryan
www.gmtruckshow.com
Old 12-28-2007, 12:03 PM   #8
BACKYARD88
BACKYARD88's Avatar
No springs, springs are BAD
-Mike Owen-
Old 12-28-2007, 12:33 PM   #9
SCOTI
SCOTI's Avatar
The bolt spacing is the same when comparing Slams vs. Stones as long as the diameters are similar (3150# stone = p/n F6873 = 7" Slam). The difference is as mentioned, the Slams have threaded inserts for bolts; the Stones have studs. I like using bolts better because you can vary the bolt length if required. If the studs on the Stones aren't long enough, it takes some creativity to securely mount them.
Running 20's won't alter things as long as tire sizes remain similar to original sizing (27~29" OD).
2.5 spindles + 2" coils = 4.5~5" drop. Bags as a direct swap should get you between 5~6" of drop which is right on the limit of 'needing' a c-notch. If you're right on the edge of needing to c-notch, bags would definitely help because they could/would add more clearance w/inceased air psi. vs. a fixed height coil.
Also.... if you need a little more drop, add some lowering blocks (which I highly recommend because they help increase the amount of shock travel).
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 12-28-2007, 12:38 PM   #10
5150
C10 Club Tennessee
5150's Avatar
I was talking to Tim Christian earlier and he told me that he didn't think I'd need a C-Notch if all I was after was the same stance my truck has.
Scoti, Do you think I should just go with a 1 inch lowering block to be safe?? Can't hurt right?
Bryan
www.gmtruckshow.com
