Old 12-25-2007, 09:22 PM   #1
SRH916
1975 C-10 Silverado LWB
SRH916's Avatar
Thumbs down Billet Grilles
I am thinking of buying a billet grille from LMCtruck.com, but as I was thinking about it, how will I be able to open the hood, it doesn't look like there is an opening for it. Do the grilles sit back farther than the stock ones? Is there something I am missing here? If anyone could help me understand it would be great. Thanks!
SRH916 is offline   Reply With Quote
Old 12-25-2007, 11:14 PM   #2
69face
69face's Avatar
Re: Billet Grilles
no there are no openings. it is a pain in the fingers(literally) my fingers get scratched up everytime i try and open the hood and eventually the grilles get bowed up or down however you have to maneuver them to get your fingers in. but daggumet they are just gorgeous. it's a win/loose.
""A bagged vehicle is only as good as it's wheel/tire combo!" -getlowness!
my build thread http://67-72chevytrucks.com/vboard/s...=223747:metal:
I'M SO SO CAL!
69face is offline   Reply With Quote
Old 12-26-2007, 06:32 AM   #3
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: Billet Grilles
Sounds like you need to mod the latch so you can get to the release.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 12-26-2007, 06:33 AM   #4
Pyrotechnic
Pyrotechnic's Avatar
Re: Billet Grilles
Or go to the junkyard and get parts for an in the cab hood release setup.
Pyrotechnic is offline   Reply With Quote
Old 12-26-2007, 06:51 AM   #5
tvblazer78
Low & Fast!
tvblazer78's Avatar
Re: Billet Grilles
Ken hit it right on the head, I made my latch release a little longer so I can use the end of my fingers to open it. works good..
tvblazer78 is offline   Reply With Quote
Old 12-27-2007, 07:27 AM   #6
wildmanaaron
Re: Billet Grilles
Those billet grilles that LMC has can be bought a lot of other places for a lot cheaper! Those grilles on eBay that are made in Taiwan are just as good in my opinion.
wildmanaaron is offline   Reply With Quote
Old 12-27-2007, 09:52 AM   #7
xtreme80
Wishin' I had more money!
xtreme80's Avatar
Re: Billet Grilles
I had no problem getting my hand in between mine to get to the latch. In fact, I'll sell it to you if you want. I got a new grille.
xtreme80 is offline   Reply With Quote
Old 12-27-2007, 12:13 PM   #8
Ivan D.
glamoros piece o' lowlife
Ivan D.'s Avatar
Re: Billet Grilles
How does that work? My truck has that listed on the build sheet, option #1T44 - INSIDE HOOD RELEASE, and all I got is the lever with cable to pull on to release the main latch, I still have to put my hand through the grille to release the safety-hook latch, which I imagine won't be fun with a billet piece right in the way...
The more I drink, the more I drink, the more I drink...
diesel, reg cab, long bed, 4 across the rear, single stack, wooden stakes, and lotsa lights - the Hay Express
Ivan D. is offline   Reply With Quote
Old 12-27-2007, 08:20 PM   #9
xtreme80
xtreme80's Avatar
Re: Billet Grilles
That's exactly how it works. Anything with a safety latch will still require you to pop it from under the hood/grille area. I suppose you could cut off the safety latch, but it could save your hood one day.
Old 12-27-2007, 08:39 PM   #10
Pyrotechnic
Re: Billet Grilles
Really ? I had assumed that with an inside hood release that the safety release lever would be under the hood, so once you popped it, you just stick you fingers in the gap you just created and unlatch it, just like a lot of newer cars.
Of course, I just assumed this...which is the problem...my mistake. Never had a truck with an inside release.
Old 12-27-2007, 09:22 PM   #11
xtreme80
xtreme80's Avatar
Re: Billet Grilles
Neither have I, and mine was also an assumption, given the style of the hood latches on these trucks. You may be right man, I don't know for sure.
Old 12-27-2007, 09:34 PM   #12
sighlurr
______________
sighlurr's Avatar
Re: Billet Grilles
There's a big difference with the bar grilles, or tube grilles, and the much thinner billets.
sighlurr is offline   Reply With Quote
Old 12-27-2007, 10:04 PM   #13
Ivan D.
Ivan D.'s Avatar
Re: Billet Grilles
Nah man, tis still behind the grille, I guess I can modify it to open between the hood and the front clip by cutting off then re-welding the handle up higher, but tis more work that tis worth for me right now
How do y'all open yer hoods is there a lever or something y'all yank of through the grille?
Old 12-27-2007, 10:20 PM   #14
SRH916
SRH916's Avatar
Re: Billet Grilles
yeah, there is a lever i have to push up on through the grille. i cant see how i would be able to reach it with a billet grille though. oh i have a 1975 chevy btw.
What would be needed for an in cab release, if i had one of those, im sure i would be able to make something to get around the problem.
Old 12-28-2007, 02:45 AM   #15
smills78gmc
Re: Billet Grilles
Some billet grilles come with a rod you install that allows you to open it from the bottom. Mine came with 2 rods, it gives you the option to open it from the left or the right. I think there is some drilling invovled.
smills78gmc is offline   Reply With Quote
Old 12-28-2007, 10:13 AM   #16
bmartin9122
bmartin9122's Avatar
Re: Billet Grilles
Yup. Here is mine. It is made by Carriage Works. (see sig for link)
you can see the rod extension (part of grill kit) hooked into the OEM latch:
intermediate rod bracket:
79 GMC Sierra Grande K15
--PPG paint code 62608 Sunburst Orange Metallic (WA802K)
--Gentex auto-dimming rearview mirror model K31
--Carriage Works billet grille model 40071
--Go Industries 2.5" tubular stainless headache rack
--Sylvania Silverstar sealed headlights model H6024ST
--Texas Saddlebags center console model 101
--Brown's Welding class IV V-5 pipe bumper
--Ramsey RE8000 winch
--33" tires
bmartin9122 is offline   Reply With Quote
