12-26-2007, 05:39 AM | #1 |
computer illiterate
th350/np205 help
my k20 has a new th350 in it which shifts fine no problem there but i have a transmission fluid leak and it appears to be coming out of the 2 outputs on the transfercase. the 205 runs gear oil so why is there trans fluid coming out of it? is it overflowing coming from the trans into the transfer case? is there a seal that could be causing this? i just want to know what to look for before i tear it apart
72 2wd blazer 72 swb 4x4 |
12-26-2007, 05:50 AM | #2 |
Well, Whoop-dee-do!
Re: th350/np205 help
There are seals in the adapter between the trans & t-case. When they go bad, ATF runs into the t-case. Sounds like you have a little project to do!
You will also need a new gasket for the adapter to t-case. Don't use just silicone alone, or it will crack the adapter when you tighten the bolts. I'd clean the adapter up good & inspect closely. They are prone to crack anyway.
'68 GMC shortbox 4x4 350/SM465/T221- bought it in '83 SOLD '72 K20 500 Cad/TH400/NP205 SOLD '92 Chevy 2500 6.5 mech TD 4L80E crusty daily driver '72 Monte Carlo... sweet low mile toy '11 Dodge Challenger IE 392 6spd... midlife car |
12-26-2007, 05:52 AM | #3 |
computer illiterate
i take it if it is cracked that will make it leak also? got any part numbers for the seals, as my local guys are idiots. if the adapter is cracked where can i get a new one? price? part number?
12-26-2007, 06:12 AM | #4 |
Well, Whoop-dee-do!
If the cracks are deep enough it can leak externally. Yep, parts store guys rarely get the right seals for a NP205. But it is tough to get them right, as there were several changes thru the years. Even sources that sell NP205 reseal kits usually don't get it right. I'd buy the gasket kit, and seals referenced to part numbers &/or dimensions of your old ones. You might have to go with a tranny shop or online source for the gasket kit. 4 wheel parts or someone on ebay usually has them. I don't know if adapters are available new, used can be hard to find (not cracked), & often go for $150+.
12-26-2007, 06:22 AM | #5 |
Member #1049
The adapters generally crack on the top and normally will not leak trans fluid into the transfer case, but will allow 90wt to seep out.
Most of the time the ATF in the transfer case is due to either bad seals in the adapter and/or a worn coupler sleeve. I am not sure if the adapters are availible new from GM anymore, used ones usually run $100 and up. (there are two on Ebay) Seal part numbers: TIMKEN Part # 471869 BCA/NATIONAL Part # 471869 {Oil Seal / Nitrile / Shaft Size=1.937" Housing Bore=2.686" Outer Diameter=2.69" Width=0.375"} New Process 205 2 Spd. Part Time Transfer Case |
12-26-2007, 06:49 AM | #6 |
Just got done with the same issue with mine. PO said the adapter was cracked so I found a few on ebay, craigslist, and on this forum. After I tore it apart, I found that PO didn't know what was wrong. Turns out that the adapter was not cracked.
The problem was that one of the two seals in the adapter was cracked in about 8 places and the o-ring on the TC input shaft was cracked. I went ahead and did a complete rebuild of the TC and twin sticked it while I had it out. Take the seal P/N to NAPA as they can match up the correct seals for you, got mine in one day. The TC rebuild kit does not include those seals. |
12-26-2007, 06:49 AM | #7 |
computer illiterate
wow thanks guys. is ther an easy way to tell if the sleeve is worn? i looked on ebay just a minute ago and didnt see any adapters?
12-26-2007, 06:53 AM | #8 | |
I need to finish up this other thread but I put a few pix up and some discussion on what I just did -->http://67-72chevytrucks.com/vboard/s...d.php?t=266278 |
12-26-2007, 07:14 AM | #9 |
Member #1049
For some reason I cannot get the links for the one on Ebay to work.. so here is the Ebay item number:
180196928665 Last edited by Livrat; 12-26-2007 at 07:16 AM. |
12-26-2007, 07:16 AM | #10 |
computer illiterate
link didnt work for me
12-26-2007, 07:18 AM | #11 |
computer illiterate
got it thanks, i dont know how i missed this.
12-26-2007, 10:07 AM | #12 |
computer illiterate
ok i got it apart and the big o ring on the trans side looks good as well as the 2 seals inside that ride on the sleeve. i didnt see any cracks in it either. but both seals where stiff so i removed them anyway and the sleeve does have a groove on it but not big enough to catch a fingernail so is it good or bad? the groove is on the transfer case side. how can i pressure wash this without getting water in the case or will it hurt if i do?
72 2wd blazer 72 swb 4x4 Last edited by meathead95; 12-26-2007 at 10:09 AM. |
12-26-2007, 10:30 AM | #13 | |
Pressure wash, that's part of the reason I went ahead and did the rebuild.. |
12-26-2007, 10:32 AM | #14 |
computer illiterate
you think if i pressure wash it and then just drain what water gets in their it will be fine? what weight oil you use in it? where can i get a new sleeve at?
12-26-2007, 10:38 AM | #15 |
I'm not to crazy about getting water into something with so many bearings and places to catch water. It can be hard to get it all out once it's in. 90wt gear oil is what is called for. So, the same stuff that goes in the differentials. Think I wound up using 75w90.
12-26-2007, 10:42 AM | #16 |
computer illiterate
ok thats what i planned on was 80w90 do you recall how much it holds? im just gonna clean it with a screwdriver and wire brush. how about that sleeve? do you know where i can get one
12-26-2007, 10:49 AM | #17 | |
Try these guys for a sleeve quad4x4.com. They may or may not be able to help. |
12-28-2007, 02:50 AM | #18 |
What causes this? I'm confused as to why replacing that paper gasket with silicone will cause the adapter to crack.
1969 K10 - V8, 465, 205, 12 bolt, D44 2002-current 1969 K20 - V8, 465, 221, Eaton, D44 2012-current Nothin' but drums on all 4 corners! past horses in the stable 72 C10-short step (97-02), 68 C10-long fleet (06-12) |
12-28-2007, 08:19 AM | #19 | |
Another detail is that most of the bolt holes in the TC are through holes so you'll need to use some sort of thread sealer on your bolts so you won't have a bunch of leaks at each of your bolts. |
12-28-2007, 01:51 PM | #20 |
computer illiterate
ok these local parts people are bigger idiots then i thought. do any of you have the part numbers for the paper gasket and o ring so i can get all the parts ordered.
12-30-2007, 07:31 AM | #21 |
computer illiterate
i went and ordered the seals bca national 471869 that livrat posted and they where clearly 1/16th larger o. d. anymore help?
12-30-2007, 12:32 PM | #22 |
computer illiterate
i went to an older napa well used by the local hot rodders and low and behold he took the national number off the seal and within 5 min he came back and told me it was an adapter seal and the brand of the new ones i ordered are nos and the part number is 19760 for whoever wants to know. it just amazes me how autozone, oreilly, and even the national website couldnt get anything off of the number on the seal but this old a$$ napa did.
