2006 6 lug the same as 67 6 lug????help
MERRY CHRISTMAS
HO HO HO 's Have a good deal lined up on rims and wheels but they are on a 2006 Yukon with six bolt. Not sure if it is the same dim's .......anybody know Be a big help... ![]() ![]() ![]()
1968 Chevy C10 307 3ott fleetside 1967 Chevy C/10 V8, 3spd, fleetside lwb.Sold 1967 Chev C/10 step, 383, M21. SOLD |
Re: 2006 6 lug the same as 67 6 lug????help
From what I've read they'll fit the rear with no problem but the front will be an issue. The center of your front hub will need to be reduced or the center of the '06 rims will need to be clearanced to fit. And I'm not sure if the '96 wheel have the same offset either...
Probably best to do a search on the forum and see what you find. good luck.
78 C10 LWB Super Cheyenne |
don't have the ad right now but I think they are Evo 20" 6 bolt.
He is just going to measure the overall size of the tire. HXW and call me back. |
They fit his 2006 yuk 6 bolt.
Hopefully the ceter hub is big enough in the fronts. If they are 9+'' wide I'll get one over here and try it out. |
29" X 10.5"
Hoping for 25-27" ?
I have a radical idea!
I have '75 8" Blazer Ralley's on my 2000 Z71, so I'd assume they would be the same.
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435 ‘72 C-10 SWB , 350 4bbl, TH350 '69 C-10 SWB , 250 L6, 3 OTT '69 GMC C3500, dump truck, 351 V6, NP435 '84 M1009 CUCV Military Blazer 67 C-30 Turbodiesel build thread http://67-72chevytrucks.com/vboard/s...d.php?t=254096 My trucks http://s226.photobucket.com/albums/d...ediafilter=all Member of the 1-Ton Club! |
#7 | |
Aftermarket wheel fit will vary based on the manufacturer.
Never assume . . .... The newer 6-lugs are similar in the pattern but the front hub on a drum brake truck will require modification for stock wheels to work.
Aftermarket wheel fit will vary based on the manufacturer. This is what I was thinking. have to check the front hub by trying one. I think I can only go with 27" tire up front. I have tryed out alot of tires on the setup. I do have bags to go in still so I might gain the difference with the air bags. Little hiegher ride hieght won't hurt at this point. ![]()
I am a Referee of life.
The other issue will be backspacing.Not being a fan of the "BLING" wheels I haven't followed the threads onn it but it seems like the BS is off for fitment.I think some members have used spacers to correct the problem.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
Active Member
![]() Join Date: Jun 2002
I had a chance to buy a set of Escalde rims and they did fit the hub but back spacing caused it to bind and the center cap would not fit, hub stuck out too far. 3.5" spacers would have taken care of it but the cost for a quality set wasn't worth it. Plus I'm not a big on using spacers. Best way is to put them on to check.
1969 C10 350 3spd 1995 GMC 3500 XC 350 dually When Thomas Edison worked late into the night on the electric light, he had to do it by gas lamp or candle. I'm sure it made the work seem that much more urgent. George Carlin |
Spacers are not an option.
No to spacers. He is bringing one over today so I'll take some pics
Most afternarket wheels are lug centric not hub centric so the hub size probably wont be an issue and the front hub should be the same as the center of the rear axle so if they fit the back they'll fit the front
1968 Short Fleet 350/700r4 http://67-72chevytrucks.com/vboard/s...d.php?t=249435 1997 Bagged XtdCab Vortec350/4L60e http://67-72chevytrucks.com/vboard/s...44#post2286144 1993 XtdCab Longbed 4x4 6.5Turbo/NV4500 "Daily Driver" 1985 Toyota XtdCab 4x4 22re/W-56/Dual T-cases, Doug Thorley Header, Homebrew front and rear spring packs, Tons of Mods to suspension and drivetrain, 35" boggers, coming soon ARB's and 5.29's, Possible 4.3/700r4 swap |
