Pitman Arm to Drag Link Torque?
What do you torque do you apply to the nut that holds the drag link onto the tapered shaft of the pitman arm?
Richard Dobson |
Msgt USAF Ret
![]() ![]() Join Date: Jan 2005
Re: Pitman Arm to Drag Link Torque?
My Haynes manual says Pitman arm to relay rod nut is 60 ft lbs.
VetteVet metallic green 67 stepside 74 corvette convertible 1965 Harley sportster 1995 Harley wide glide Growing old is hell, but it beats the alternative. |
![]() Join Date: Mar 2003
If you are talking about the 1-5/16 nut on the sector shaft, then 150-180 should do the trick
The nut on my sector shaft is 15/16 and it is not a castle nut with a cotter pin. It is a locking nut with deformations on the side of the hex.
Richard Dobson |
So for my application the torque is 150-180 ft./lbs. since I don't have a castle nut with a cotter pin? Thanks
Richard Dobson |
