Old 12-26-2007, 08:23 AM   #1
72C10chevy4x4
UK Wildcat Fan!
350 won't start-where should I look?
it's a 78 350 w/ the coil built into the cap (is that an HEI?).
The engine will NOT start. replaced the inline fuel filter in the 2 barrell carb-tested it and there is plenty of gas coming out (pumped it manually and observed it squirting in). Air-tryed placing a towel over the carb, closing the butterfly shut, partially open, no indication it wants to start. finally, replaced cap,rotor and checked spark at end of a plug-it's there, but not strong. not sure how strong it should be, but there is spark. will go back and replace plugs to see if that helps.
how about the spark-how much spark do you NEED to start the engine? gas and starting fluid in the carb made no impact on it starting and I hooked up the jumper cables to get it turning more quickly-still no dice.
help! I've exhausted all my ideas except for a weak coil-would like to know it's bad before buying another (is there a test?)
72C10chevy4x4 is offline   Reply With Quote
Old 12-26-2007, 04:08 PM   #2
72C10chevy4x4
UK Wildcat Fan!
Re: 350 won't start-where should I look?
problem fixed. Turned out to be the plugs-as soon as a new set was installed, the engine started on the first shot. they were black and 'fouled'
Old 12-26-2007, 06:00 PM   #3
xtreme80
Wishin' I had more money!
xtreme80's Avatar
You probably flooded it, and in the time it took you to replace plugs, it cleared the cylinders, and started. New plugs will definately help, but I doubt that it wouldn't start because all the plugs were that bad. If they were you got some serious problems there!
And yes, coil in cap is HEI
xtreme80 is offline   Reply With Quote
Old 12-27-2007, 02:06 PM   #4
72C10chevy4x4
UK Wildcat Fan!
I would have thought the same thing about coming back later after flooding it. The problem was recurring-I had three different mornings of trying to start it, all with no 'luck'. The plugs looked to be gapped a little more closely then speced
