12-26-2007, 09:49 AM | #1 |
clutch linkage question -
Is this how the linkage sets in the throw out fork? It doesn't seem right, seems like it would slip down. If you have a picture how it should look or if this is how it should look, let me know. I replaced the spring and forgot what it looked like before.
'67 SWB Fleetside ZZ4/350/Tremec 5-speed/4link/Scott's IFS - and fun as heck! SOLD Click here to support the board Philippians 4: 6-7 |
12-26-2007, 10:15 AM | #2 |
Fabricate till you "puke"
Re: clutch linkage question -
That is set up properly, but the rod should stick through the back of the fork to hold things in place. i think the rod may have been shortened sometime in its life? you could weld a pc of bolt to the backend of the rod, or maybe shorten the front side of the little pc that touches the fork, then re adjust the clutch(if you have enough adjustment on the front of the rod). crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... Last edited by crazy longhorn; 12-26-2007 at 10:16 AM. Reason: spelling |
12-26-2007, 02:02 PM | #3 |
Looks like he has a spacer between the wedge and the shoulder of the rod. Spacer should not be there. How about a pic of the rod at the bell crank where the adjustment takes place.
12-27-2007, 05:37 AM | #4 |
That does look like an added spacer,now that I take a 2nd look....
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
