water, water every where
I started to take out the interior of the GMC to repair the floor pans in the cab. I was surprised to find a lot of water on the floor on the passenger side. Plus the water on the drivers side.
On the passenger side it's where your left foot would be. I'm thinking the water might be coming in through the ventilation system (not coolant though, like a heater core leaking). On the drivers side it's below the handle for the parking brake realease. Any ideas or experience on what to look for to stop it from leaking would be great. Thanks guys! |
its all about the +6 inches
Re: water, water every where
Cowl. Every truck I've owned had leaking cowls.
rust in the cowl is a big one, another thing to consider is the windsheild frame..every truck ive seen always has rust in the same spots
"Dixie Destroyer" 71 C10 LWB Fleet Future Blown Prostreet Monster |
Rottenwood Garage Member
Cowl, Cowl, Cowl
2004 Chevrolet Suburban C1500 2001 Chevrolet 2500HD Crew 6.0 1999 Harley Davidson Electra Glide 1972 Chevrolet C-20 Custom Camper "Dump Truck" 1972 Chevrolet C-20 Suburban "Big Green" 1969 Chevrolet C-50 Wedge Hauler "Leonidis" 1966 C-10 2x4 short fleet 327 4 speed "Race Truck" 1952 Plymouth Cranbrook "Rican" (my grandfathers) 1931 Ford Model A Coupe "Black Beauty" 1930 Ford Model A truck "Club Cab" 4x4 Rottenwood Garage and Speed Shop.....where everything must be racy! It's not just a hobby..It's a LIFESTYLE!!! Thanks for nothing Barrett-Jackson You cant fix stupid or teach accountability! Time wasters, looky Lous and tire kickers are everywhere! |
thanks guys. Now how do I go about fixing it?
You can remove the vent shutters and clean the accumulated trash out ie. rotten leaves pine needles etc. They're not draining properly.
Worst case: If your windshield frame is rusted through, you have some sheet metal work to do.
'72 GMC SWB C1500 Custom, frame-off in progress. 383 SBC, 9:1CR, Comp Cams XE262H, Scat internal balanced crank, Eagle SIR 6" rods, Keith Black dish pistons, Dart Iron Eagle 72/180 heads, Weiand Stealth intake, Stewart stage I water pump, Holley 4bbl vac sec, TH350 with B&M Shift Improver Kit. 12 bolt positraction. ![]() ![]() ![]() Last edited by Sweet72; 12-27-2007 at 12:26 PM. |
Old Skool Club
![]() Join Date: Jun 2001
Remove the cowl (piece of sheet metal that has the wiper stalks sticking out), then remove the front fenders. In the area behind the fenders, in front of the area where the doors are hinged, is the portion that deteriorates when water, dirt, and leaves are allowed to accumulate. Get a plasma cutter, can opener, whatever, and open up to give you some access to the enclosed portion. At the bottom of the plenum, cut a hole big enough for a rat, or cat, or whatever gets in there to also get out.
The idea is to create a big enough hole that stuff will not be trapped. At the same time, you will be patching whatever is leaking water to the inside of the cab. Finally, like I am doing, "shave" the cowl and don't let any water get into the plenum. If it doesn't get into the plenum, it won't get into the cab. Then, pray it all works like you planned.....Murphy's Law will prevail and at the most inoportune times.
Member Nr. 2770 '96 GMC Sportside; 4.3/SLT - Daily driven....constantly needs washed. '69 C-10 SWB; 350/TH400 - in limbo The older I get, the better I was. |
Old Skool Club
Old Skool Club
