Old 12-26-2007, 07:00 PM   #1
bigblock79
67 Chevy Stepside
bigblock79's Avatar
Help please won't run
The other day i was comeing home. it shut off like if i had turn the key off. i got out and the big starter wire from the battey to the starter was burned to the header pipe. i pulled it off and it was not harley burn thru the red cover on the wire. i lost all power to every thing. what do you thank it is. thanks for the help. and the small wires ant burn none.
1967 Chevy stepside
1976 BIG DOOLEY 454 turbo 400 4:11
bigblock79 is offline   Reply With Quote
Old 12-26-2007, 07:54 PM   #2
sick69
sick69's Avatar
Re: Help please won't run
Start looking for the fusable link thats toast. I had several problems with the one at the starter due to heat issues. Might be a good place to start the search.
Frank
70 chevy lwb c10
454/th400 and a 9" rearend
suicide doors, marker light fuel fill, 4" cowl , mini tub
sick69 is offline   Reply With Quote
Old 12-26-2007, 09:03 PM   #3
xtreme80
Wishin' I had more money!
xtreme80's Avatar
Frank
xtreme80 is offline   Reply With Quote
Old 12-27-2007, 08:56 PM   #4
BabyBlue
The Peacemaker
BabyBlue's Avatar
If the fusable link is fine then replace the battery. I had the same thing happen to me about 100ft from my house after trying out some new headers. Headers burned through the insulation on the positive cable to the starter and fried the battery. I replaced the battery and the cable the next day and everything worked fine.
1978 Chevy 2wd Stepside
aka "Audrey"
Cordova brown with mandarin guts
79k original miles & being restored
1979 Chevy 2wd Short Wide
aka "Emma-Jayne"
2019 Chevy Tahoe LT
Previous rides:
-2002 Firehawk T/A, 2006 Trailblazer SS AWD, 2014 GMC Sierra RCSB, 1971 2wd Blazer, 1996 SNB, 1997 2dr 2wd Yukon, 2001 Silverado RCSB, 2011 Silverado Z71 4x4, 1982 2wd Blazer, 1997 2dr Tahoe, 1970 Chevelle SS, 1972 2wd Blazer, 1986 Silverado Stepside, 1995 S-10, 1985 Silverado SWB.
BabyBlue is offline   Reply With Quote
Old 12-28-2007, 07:52 PM   #5
bigblock79
67 Chevy Stepside
bigblock79's Avatar
the battery is still good. it still wont do nothing. i guss i got to change some wires out how does the wireing are to be on a 73 any got a wireing table
1967 Chevy stepside
Old 12-28-2007, 07:54 PM   #6
xtreme80
xtreme80's Avatar
You should only have one main wire running from your battery to your starter, then everything breaks off of there.
Old 12-29-2007, 11:37 AM   #7
72lb4x4
Shorting the big battery cable will create a lot of current through the big battery cables, and possibly fry them, or the battery...
What's the voltage measured accross the battery?
If its around 12.5V, I'd be looking at a bad cable connection, or fried big battery cable.
What's the voltage measured from the connector block on the fender near the battery to ground? I'm assuming there is a connector, but I haven't looked under the hood of a 73 in a lot of years.
72lb4x4 is offline   Reply With Quote
Old 12-29-2007, 05:53 PM   #8
bigblock79
67 Chevy Stepside
bigblock79's Avatar
battey is good. the cable is good. the starter is good. i dont have power on nothing
1967 Chevy stepside
Old 12-29-2007, 06:44 PM   #9
xtreme80
xtreme80's Avatar
Ignition switch maybe? You may have fried the ignition switch, and even though you turn the key on, there's no power going through the switch to allow anything to come on. Time to get out a test light and multimeter and start testing things. Once you get to the ignition switch make sure it's got power to it using the test light. If it does, but the accessories don't have power once the switch is on, I would try replacing that.
Old 12-29-2007, 07:49 PM   #10
bhunt31
krazy hillbilly from Kentucky
bhunt31's Avatar
should be a fuseable link mounted high on the firewall behind the distributor, did you check it?
1969 Chevy CST/10
"Old School lives and breathes in the heart of a chosen few "
1984 Chevy C10 Silverado
"Life, Liberty, and Ford's Pursuit of Chevy taillights"
You say "Obsessed with my trucks" like it's a bad thing
bhunt31 is offline   Reply With Quote
Old 12-29-2007, 07:50 PM   #11
72lb4x4
So no lights or horn?
What makes you think the battery is good?
What makes you think the "cable" is good? I guess you mean the big cable that got melted to the header?
What about all the other cables you've been asked about?
Old 12-29-2007, 07:51 PM   #12
89 crew
Also check the post on the fire wall. On my 90 burb it had intermittent connection there made it quite the pita to track down.
89 crew is offline   Reply With Quote
Old 12-30-2007, 10:49 AM   #13
bigblock79
67 Chevy Stepside
bigblock79's Avatar
So no lights or horn? No
What makes you think the battery is good? Tested it
What makes you think the "cable" is good? I guess you mean the big cable that got melted to the header? tested it to. volts is still going thur it and it only melted barely thru the cover
What about all the other cables you've been asked about? test them. and i put a jumper wire to get pass the fuseable link. it is dead no volts going past the wire on the junction block on the fire wall. i got fire to ther and thats it
1967 Chevy stepside
Old 12-30-2007, 11:10 AM   #14
xtreme80
xtreme80's Avatar
Did you check the ignition switch yet?
Old 12-30-2007, 11:37 AM   #15
72lb4x4
Assuming "nothing" means nothing, his headlights, horn, brake lights, etc. don't work. Since these don't need the ignition switch, its not likely the problem.
If he shorted the big starter cable to a header, the current is going back through the block through the ground cable to the battery. Thus, its probably not something on the low current side of things...
Old 12-30-2007, 12:04 PM   #16
xtreme80
xtreme80's Avatar
Didn't think of that... my mistake.
Old 12-30-2007, 12:23 PM   #17
bigblock79
67 Chevy Stepside
bigblock79's Avatar
ok i got power back to the firewall junction block. thats as far as it goes. it don't go pass that. i got a jumper wire on it and it still don't go no father. could it be that little junction box it self. i thought a jumper wire would solve that. it got me stump. thanks for all the help
1967 Chevy stepside
Old 12-30-2007, 04:01 PM   #18
89 crew
My burb lost it in the wire- terminal on the firewall. check incoming and out going. it either has to be wire-terminal, or resistance between terminal and post.
