Old 12-27-2007, 06:31 PM   #1
BLUE THUNDER
BLUE THUNDER's Avatar
Got really ambitious this weekend.
Well guys I finally had some time off from work to work on the Blazer. I was really pumped for the Holiday weekend to be here. I decided to do the engine swap so I could finally drive my Blazer around the block. I had everything planned out, buy parts that i needed on Saturday morning and pull the motor out Saturday afternoon. My friend from work was supposed to come over with his cherry picker to help out. Well you guessed it, dude never showed up. Ba$tard pulled a no call no show. I was'nt gonna let that slow me down. I went to a tool rental down the street and rented one. While I was there some guy pulls up in an awesome '72 CST. We got to talking and I gave him the web address and told him to check it out. Well that only added fuel to the fire, so I rushed home and got to work. That's when the $h!t hit the fan. I couldn't get the nuts from the exhaust to come off. They were rusted solid. Enter Sawzall. Then while climbing in and out of the engine compartment I suffered my first loss. I managed to break a slat off my nearly perfect grille. Once I got the motor out I started to transfer everything from the 350 to the 305 that was going in. One of the rams horn exhaust manifolds broke while I was freeing it from the head. Last but not least, I found out while I was setting in the the 305 that the torque converter does not fit the flex plate. I think I'm gonna have to take the one off the 350 and put it on the 305 so the converter will fit. I don't want to ramble on , but does anyone have any suggestions. The 305 came out of a 1978 malibu with an automatic tranny (a 200) I believe, and a 2bbl. Will swapping out the flexplates solve my problem? Here are some pics. BTW, thanks Jtrux for comming over and helping out. I really appreciate it.
BLUE THUNDER is offline   Reply With Quote
Old 12-27-2007, 07:40 PM   #2
68K20 x Drill
Re: Got really ambitious this weekend.
You should be fine to use the plate and converter that came with your truck.
Don't try to install the tranny with the converter bolted to the motor, or more stuff will likely break.
And congratulations on gettin' a lot more done this weekend than I did.
68 Chevrolet k20 Longbed 350 SM465/205, Dana 44, 14bolt, Power steering, Power Disk Brakes, 35" BFGs.
84 Chevrolet Suburban K20 6.2 Banks turbo TH400/NP208 Now with G80
68 GMC C20 Parts? Truck
And a few cars
68K20 x Drill is offline   Reply With Quote
Old 12-27-2007, 10:18 PM   #3
72armyswbtruck
72armyswbtruck's Avatar
Sorry to hear about the Now call no show and the broken fins on the grill, god luck on the swap,
"Remember, They can Kill You, but they can't eat You, That's against the law!!!!!!!!!"
72armyswbtruck is offline   Reply With Quote
Old 12-28-2007, 05:57 AM   #4
AJs72K5
AJs72K5's Avatar
You hit a few hurdles, but still got a lot done. Congrats on getting started. I'm still waiting for parts...
- AJ
Gray Matter Build - 1972 K5 with some stuff
AJs72K5 is offline   Reply With Quote
Old 12-28-2007, 07:04 AM   #5
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Congrats keeep on pluggin away you will get her done.
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 12-28-2007, 07:09 AM   #6
Big Block
Big Block
Big Block's Avatar
Sorry about your grill. Yes just use the flex plate and converter from your blazer. I have installed engines by myself a couple of times. But have gotten the lovely wife to help in pinch. Go luck.
Big Block is offline   Reply With Quote
Old 12-28-2007, 10:49 AM   #7
Big J
Its lookin' like a Blazer!
Big J's Avatar
Don't let the silly stuff get ya down. If it wasn't for chit hittin' the fan it'd be too easy....... Not to long ago I had to use a cutting torch to cut out an easy out that I broke off in the broken bolt that I was trying remove from a head. There was some cussing involved but I made it through it,lol.... Keep at it and it'll all work out. Any clues as to whats wrong with the purdy motor you pulled out?
BAZINGA!
My Build
Big J is offline   Reply With Quote
Old 12-28-2007, 03:08 PM   #8
BLUE THUNDER
Well you said it right, it did look good. Really was just the top end, intake,carb, valve covers, and air cleaner that made it look good. Fact of the matter was that it sat in a barn for eight years without a carb or plugs. I was really hoping luck would be on my side if I replaced the car and put new plugs in it. I even changed the distributer to an HEI, but could never get it to start. The motor had no compression in #1 cylinder and had a lot of crud[I] under the valve covers. I bought the 305 for $150.00 and it runs. I just want to be able to drive the Blazer around while I build the 350 the way I want it. Will I run into any balancing problems when I change out the flexplates? I presume that the harmonic balancer will take care of any vibrations. Please let me know. Thanks. Mario.
Old 12-28-2007, 03:23 PM   #9
1966gmc
Why does it taste purple?
1966gmc's Avatar
As long as both engines are internally balanced you will be fine.86 and later SBC engines are externally balanced while pre 86 are internally,with the exception of the 400 which is externally balanced as well.
1966gmc is offline   Reply With Quote
Old 12-28-2007, 04:51 PM   #10
BLUE THUNDER
Awesome, that's just the info I needed to continue. I'll probably need to wait until Sunday to continue. I'ts been getting dark pretty early here, so working on it during the week is out of the question. Thanks alot. Mario
