![]() Join Date: Oct 2006
sheet metal gauge?
What gage sheet metal do I need to weld up the firewall? I am removing all the ac stuff and want to fill in the holes. Thanks
BTW its a '75 K10 -Lance
------------------------------------------------------ -Lance 2000 Chevy C2500, 5.7, 4L80e 1999 Suburban K2500, 7.4, 4L80e 1980 Camaro..son's car...PROJECT |
Re: sheet metal gage?
I cant believe that no one has done this.....anyone know? Thanks
-Lance
New Member
I would like to know also.
The One And Only !!!
Sorry I can't give you a number guys, I bought a new COMPLETE front end including hood and new doors for mine.
I used the old doors and hood for patch panels, You may hit the scrap yard for a damaged door/hood to cut panels from. May even be cheaper than buying new sheet metal.
93 Jeep XJ 88 Buick La Sabra Toys; 88 TA-GTA in the works.... 97 GMC Ext. Cab 502 Crate 5 Spd......Sucks Gas But Haulz Azz ! ![]() The primary function of an Engineer is to make it difficult for the Fabricator and impossible for the Mechanic. "Why go out preserved when you can go out beat up, worn out, sliding in sideways screaming, Holy Sh!t What A Ride" !!!
Right in front of you.
I'd probably use 18ga......
Pinstriping by Josh '78 Chevy Silverado SWB (lowered, 454) '90 Chevy Sport Truck '68 Dodge Charger R/T 1930 Ford Model A Last edited by 69BBsuburban; 12-30-2007 at 06:10 AM. |
It'd be alot cooler if you did
Re: sheet metal gauge?
I've been using 20 gauge on mine. seems to be real close to the thickness of the original.
BTW, sheet metal is cheap... I just buy "drops" from the local steel retailer. Last edited by smashingchuck; 12-30-2007 at 11:27 AM. |
