Old 12-28-2007, 09:19 AM   #1
opivyrocks
1982 chevy 4x4 axle ratio
Hello,
I was wondering what ratio my truck is, The option list in the glove box has it listed as standard ratio. Assuming these are original axles what would thw ratio be?
thanks
82 siverado 1/2 ton
opivyrocks is offline   Reply With Quote
Old 12-28-2007, 09:48 AM   #2
68K20 x Drill
Re: 1982 chevy 4x4 axle ratio
Between 3.08 and 3.73?
68 Chevrolet k20 Longbed 350 SM465/205, Dana 44, 14bolt, Power steering, Power Disk Brakes, 35" BFGs.
84 Chevrolet Suburban K20 6.2 Banks turbo TH400/NP208 Now with G80
68 GMC C20 Parts? Truck
And a few cars
68K20 x Drill is offline   Reply With Quote
Old 12-30-2007, 07:46 AM   #3
opivyrocks
jacked it up spun the wheel, looks like 3 turns of the driveshaft, probably 3.08. Just a pain in all this snow, ..........oh well time to lock em in and go drift busting
thanks
jeff
Old 12-30-2007, 09:47 AM   #4
piecesparts
Parts and more parts
piecesparts's Avatar
3.42 was common gear ratio in the 4X4s in that era.
piecesparts is offline   Reply With Quote
Old 12-30-2007, 01:25 PM   #5
Dooley
Dooley's Avatar
The 1981 showroom brochure I have lists the standard ratio on a K10 as a 3.73, unfortunately the 82 and 83 brochures don't list the available gear ratios. Keep in mind that the standard transmission in 1981 K10 truck was a 3 speed stick, in 1982 the 4 speed manual was standard. Available ratios listed for the 81 K10 were
3.73 standard
2.56
2.73
3.08
3.42
Dooley is offline   Reply With Quote
Old 12-30-2007, 01:34 PM   #6
Duro5341
Duro5341's Avatar
It all depends on the tranny.....being it's a 1/2ton
If it's a 3 speed, I would say 2.56-3.23
If it was a 4 speed I would say 3.42-3.73
Duro
-1986 K10 LWB, 350 HD,TH400
3.08, 30 spline 10 bolt, with an Auburn Posi, 31" tires
All original, second owner truck
-1979 Monte Carlo, 350, 200r4, 3.73 posi
-1987 GT T-top Mustang - slow moving project
Duro5341 is offline   Reply With Quote
Old 01-02-2008, 12:36 PM   #7
ChaseDale3and8
ChaseDale3and8's Avatar
The front differential should have a metal tag bolted onto the differential cover with a number. You may need to wire brush, or clean the tag in order to read it. That number is your original gear ratio. ...Joe
I'm not speedin'! I'm qualifyin'!
ChaseDale3and8 is offline   Reply With Quote
Old 01-02-2008, 01:12 PM   #8
1969k10stepside
..And if it doesn't pull the cover and there will be numbers on the ring gear and those will tell you the ratio..I'd just do it that way,the fluid probably needs changed anyway.
1969k10stepside is offline   Reply With Quote
Old 01-03-2008, 12:26 AM   #9
MylilBowTie
Right turn Clyde
MylilBowTie's Avatar
Pulling the cover is the only for sure way to know. I don't think our trucks cam with anything lower (numerically) than 2.73 gears. The majority I have seen are 2.73 and 3.08 10 8.5 5 lug rears. I've not seen that many 12 bolts I have dealt much with the older ones. Mostly just the 81-87 2wd half tons.
My 86 C20 has 3.42 gears and a 700r4 stock. But I replace the 700r4 with a th350.
MylilBowTie is offline   Reply With Quote
Old 01-04-2008, 12:19 PM   #10
ElGracho
Gentleman Jim Driver
ElGracho's Avatar
Axle code GQ1 - Standard ratio depends on the powerteam (combination of engine and transmission), drivetrain (4x4 or 2wd) and the GVW. You can't just say 4x4 standard ratio is x.xx, you have to take into account the engine and GVW. Some heavier half tons had different standard ratios than the lighter ones.
Like 1969k10stepside said, the best way is to open up the diff and look at the numbers stamped on the ring gear. It won't have the ratio spelled out, but it will have numbers of teeth on the ring gear and pinion, you just have to divide.
Remember, these trucks are 20 years old at the youngest. Almost all have over 100k miles and could have easily worn out there original axles and had others swapped in somewhere along the line.
Joe
'75 GMC Gentleman Jim
'84 Chev C10 Short Wide - Super duper plain (manual steering, manual brakes, no dome light, no cig lighter)
'85 Chev C10 Short Wide - Super plain Vortec 4.8 4L60E trans
also: '81 K30, '83 C30 Crew Dually, '84 M1028 CUCV, '85 M1009 CUCV, another '85 C10 SWB, '89 R3500 Flatbed
ElGracho is offline   Reply With Quote
