12-28-2007, 05:37 PM | #1 |
will or won't fit?????
I found some headman headers on craigslist for a '68 p/u. I was wondering if they would fit my '72 blazer. I think they are for a 2wd but i'm not sure. They are the long tube headers and he'll take $35.00 for them. Thanks. Mario.
12-28-2007, 05:50 PM | #2 |
SKINNY TIRES RULE!
Re: will or won't fit?????
I don't think 2wd headers fit a 4wd, but hopefully someone else will pipe in.
bouncytruck 1972 K5 The Hauler 1994 K1500 Suburban The Daily2010 Kia Soul Wife's Ride2014 Fiat 500L |
12-28-2007, 06:09 PM | #3 |
Heck,my 4wd version headers barely fit...My advice is just to stay with manifolds.Too many issues (Atleast in my experience) with the long tube headers causing clearance issues between the front shackles,driveshaft,z bar,and just trying to route the exhaust on the passenger side between the frame and the t-case..Is your truck a manual or automatic? If its a manual your headers and z-bar won't work good together..
12-28-2007, 06:16 PM | #4 | |
I'm a poor spectator
2006 Jeep Unlimited IMPACT ORANGE 1993 Chevy 2500 4x4 ExCab LWB 454/NV4500 Tow rig 1977 Ford F100 2x4 LWB 1st truck I owned, still have it!!! 1979 Ford F150 4x4 SWB Built Ford Tough!!! 1971 Chevy Blazer 350 / SM465 / NP205 UNDER CONSTRUCTION Soon to have a LQ4 6.0!!! |
12-28-2007, 08:44 PM | #5 |
SKINNY TIRES RULE!
LUV found some headers that fit GQ really well. Ask him what they were.
12-29-2007, 01:51 AM | #6 |
The LuvShack Garage
Mine are Hedman "Elites" as far as 2wd headers fitting? I doubt it. Mine are
not full length, they are called 3/4 length because they are higher than my shackles. My passenger pipe was run almost straight through the transcase area instead of curved like most. There are pictures in my "GQ" siggy link. If you click it, then go to pages 13 (Headers) & then also 16-18 (Exhaust) EDIT: If you look close at pic #4 on page 13 you can see where the header used to hook to the pipe (Pipe is hung solid there) and look higher up to see the new header already mounted. (I think it was alot higher, around 6"-8") I also edited my Cardomain site w/ the Header part #'s for others to enjoy.
Owner/Op: "TN Classic Transport Carriers" The Toy: "Square Vette" 72 Hybrid Blazer Toy Barn: "LuvShack" 40 x 60 x 20 Shop Tow Piggy:"Maddy" 88 Silverado 3500 Hauler: "Feathers" 14 Aluma 8218T Last edited by LUV2XCLR8; 12-30-2007 at 07:36 AM. |
12-29-2007, 06:08 AM | #7 |
Keepin it runnin!
Just my opinion based off what I was told, there is no gain with headers over a set of center dump ram horn manifolds. This was based off of a dyno test between the two on the small block in my Blazer. Not sure if it makes a diff on how the engine is setup or not, or what it was built to do, but thats a definite possibility too.
Frank
1970 K-5 4X4 Blazer 1970 K-20 4X4 Long Bed "Liberty Means Responsibility, that is why most men dread it" |
12-29-2007, 04:21 PM | #8 |
not sure of any power gains, but i'm down to one rams horn since one broke when i was taking it off. used headers are just cheaper. mario
12-30-2007, 06:30 AM | #9 |
Keepin it runnin!
Have to agree there! With gasoline approaching $4.00 a gallon (I wonder when the rioting will start?) every penny saved is a penny earned.
Frank
