Old 12-29-2007, 07:52 AM   #1
crm318
Alright Alright Alright
crm318's Avatar
control arm shaft replacement
are there any special tools that i would need to replace the upper control arm shaft? its on a 72 cheyenne.
1972 Cheyenne
Chevrolet red and white
357ci, Vortec heads,
GM Performance high rise intake,
Comp 268H .454/.454 218/218 110 LSA
Quadrajet carb, Flowtech headers, 2.25 40 series
HEI, Curve kit, TH 350, 3.07 gears
275/60/15s on 15x8 rallies
crm318 is offline   Reply With Quote
Old 12-29-2007, 08:14 AM   #2
mbgmike
Re: control arm shaft replacement
I have heard tou can do it w/o tools but I take them to a frame shop that will still take in bench work. They charge us $15.00 each but it saves us time. They use a large press. Ours is too small to do it.
mbgmike is offline   Reply With Quote
Old 12-29-2007, 09:21 AM   #3
Rally Nova
Rally Nova's Avatar
I changed out the upper & lower control arm shafts on my '69 GMC. You will need a 1 3/8" socket for the end caps & a sturdy bench vise to hold it!! You might also need a breaker bar & a cheater to initially brak the old ones loose.
Hope that helps!!
1969 GMC C-1500
1972 Rally Nova
1988 Monte Carlo SS
2004 GMC 2500 Crew Cab
Rally Nova is offline   Reply With Quote
Old 12-29-2007, 10:26 AM   #4
JCA1972
JCA1972's Avatar
I didn't have the 1 3/8" socket so I used a pipewrench and a BFH to break the caps loose, after that it comes off really easy.
1971 C-10
2004 Yukon:
1998 Honda Accord
2008 Honda Civic
2004 HD V-Rod
http://67-72chevytrucks.com/vboard/s...d.php?t=226458
JCA1972 is offline   Reply With Quote
Old 12-29-2007, 10:39 AM   #5
71/454
Turbo Guy
71/454's Avatar
There is a good how to thread on this somewhere, that's how I learned to do mine.
1972 Gmc Custom swb intercooled twin turbo 327 10.5-1 and 12 lbs of boost, Nodular iron case super t-10 4 speed with a blowproof bellhousing, 12 bolt eaton posi soon to have moser axles.
1998 Honda CR250 fully ported, case matched, milled head, vortexed carb and revalved suspension but don't forget the woody woodpecker decal kit!
Things I've broken so far:
12 bolt diff
saginaw 4 spd many, many pieces
Aluminum case Super t-10 4 spd
71/454 is offline   Reply With Quote
Old 12-29-2007, 10:55 AM   #6
crm318
crm318's Avatar
well, i got one endcap off and the other is stripped, so getting the endcaps off isnt a problem. what will i need a press for?
1972 Cheyenne
Old 12-29-2007, 11:03 AM   #7
JCA1972
JCA1972's Avatar
the only thing that I had to use a press for was to install the lower balljoint.
1971 C-10
2004 Yukon:
1998 Honda Accord
2008 Honda Civic
2004 HD V-Rod
Old 12-29-2007, 11:16 AM   #8
Tynee
I miss this truck.
Tynee's Avatar
As stated above, the control arm shaft is nothing but a 1-3/8" socket, breaker bar, cheater pipe. Also, be very carefull not to tighten one end too far before getting the other end started when you install the new caps. Your shaft will end up "off-center."
If you are getting into ball joints, then I DEFINITELY recommend paying somebody with a big press. The press that you rent at the local parts store isn't big enough to do them. I learned the hard way. You can do your upper ball joints if you have the time and patience to grind and drill out the rivets.
'07 GMC Acadia SLT. Sweet ride.
'08 Crew Cab Z-71 short bed. Really like this truck A LOT.
Tynee is offline   Reply With Quote
