12-29-2007, 10:56 AM | #1 |
truck weight
what dose a 71-72 usually weigh?
70 Chevy C-10 short step 250/3 on the tree Owned: 71 longbed Cheyenne 70 swb |
12-29-2007, 11:50 AM | #2 |
Re: truck weight
I think the general opinion is around 4000 - 4200 lbs --- obviously more equipment means more weight
Are you retired too? Nonsense! I'm in my prime |
12-29-2007, 12:41 PM | #3 |
Eat My Rust
Re: truck weight
Our trucks weigh more then that..
I think Longhornman wieghed his '69 Longhorn in at just under 3-tons. |
12-29-2007, 12:58 PM | #4 |
Re: truck weight
nahhh --- they are much lighter than a modern truck--- just look at the difference in the frame rails. There is nothing to the interiors either, and they are single cab
I've taken my longbed (small block, steel floor, steel wheels, no options) over the scales enough at the dump to ballpark it at around 4000 lbs.
12-29-2007, 01:14 PM | #5 |
Re: truck weight
Ive got al old book somewhere that lists all the truck weights from 60-72 i cant find it right now. I know it says my panel weighs 3800lbs and if i remember correctly a half ton longbed weighed 3600lbs
the weights were probably based off a base model mabie with a 6cyl It dident say. |
12-29-2007, 03:02 PM | #6 |
Re: truck weight
My 69 with a Corp 14-bolt in rear, and a D60 up front.....AND a BBC weighed in at 5200 lbs.......I'm a puller, and I had to add MANY weights to hit the 6200 pound class limit. I would guess a stock half ton to weigh in at less than 4800 lbs......
A..........
69' 3/4 4X4 470ci BBC 700 HP.... D60/14bolt 205/465 http://profile.myspace.com/index.cfm...ndid=127691959 |
12-29-2007, 05:17 PM | #7 |
Re: truck weight
I talked to a guy here in okc with a shortbed and a big block and his weighs 4800lbs. I'm thinking that mine weighs around 4600 or so. Going by my time slips and my dyno sheets, i think i'm in the ball park.
12-29-2007, 05:37 PM | #8 |
Rolled on Paint Club
Re: truck weight
My 1970 short fleetside 2wd with a small block weighed in at 4510 lbs on the DMV scale during safety inspection.
Bob
1970 GMC 1500 swb fleetside SB 355ci. Smog heads Summit 1102 cam Performer intake and carb. Finally in about 1 piece in the yard. |
12-29-2007, 06:00 PM | #9 |
Re: truck weight
Had a 68 longbed fleetside with a 250 I6 and a 4 speed that weighed in at 4200 lbs with a quarter tank of gas. That was on a grain elevator's scale. I would hope that's accurate since they get paid by that.
1978 Chevrolet Silverado 3/4 ton 400 small block. 2000 F-250 Powerstroke 2002 GMC Yukon Denali XL Last edited by mvfd70; 12-29-2007 at 06:00 PM. |
12-29-2007, 06:09 PM | #10 |
Re: truck weight
at the dump my 69 sb 4 speed lwb with me[175] and a cross bed tool box weighed out at 4660 my short 3/4 ton 4x4 weighed 4900 with me and close to 40 gallons of fuel
common sense isn't so common anymore Last edited by wibilly; 12-29-2007 at 06:11 PM. |
12-29-2007, 09:45 PM | #11 |
Re: truck weight
the restoration packet that ive got lists a 72 longbed v8 curb weight of 3826lbs stock
-steven Alte Seele S.S. "Allison" '72 C/10 LWB 350SB/TH350 - DD PITBULL IS NOT A CRIME |
12-29-2007, 11:30 PM | #12 |
Green club
Re: truck weight
Our truck scales at work just were calibrated, my SWB fleet with a V8 weighed in at 3650 with no driver.
Mine is a stripper model, no AC and an auto.
71 short/fleet ECE 4/6 drop, LQ4/700r4/3.42 gears 70 SS396 Chevelle 427/200-4R/3.73posi 61 Lincoln Continental, black on black Son you are going to drive me to drinkin if you don't stop drivin that hot rod lincoln |
12-30-2007, 01:05 AM | #13 |
Re: truck weight
Amazing how different the weights are. At the dump, my 70 GMC lwb weighed in at 4544 empty with me in it at 180 lbs.
1997 GMC Sierra Ext 1965 Mustang |
12-30-2007, 02:25 AM | #14 |
Re: truck weight
I find the disparity in weight amazing too. Granted, 4X4s are heavier than 2X4s, and LWBs a little more than SWBs, but there seems to be at least a 20% variation with similar type trucks. Can the weighing places (DMV, Grain Elevator, Racetrack, Town Dump, truck stop, etc) be off by that much?
It'd be interesting to take the same truck to a half dozen places and see how much of this 20% difference is due to the scale rather than the truck. Since Mine's not running, I guess I just gave one of you something to do this winter.
69 C-10 SWB Fleetside 454/TH400 (For Sale) http://67-72chevytrucks.com/vboard/c...ct=1299&cat=12 70 El Camino 454 TH700 29 Model A 4-DR Sedan Deluxe |
12-30-2007, 02:32 AM | #15 |
Re: truck weight
Yeah, mine weighs ~4200#. I guess most of those scales don't really matter if they are dead on, 'cause they are weighing the difference of loaded vs unloaded... But it'd be nice if they were all the same...
1969 K10 - V8, 465, 205, 12 bolt, D44 2002-current 1969 K20 - V8, 465, 221, Eaton, D44 2012-current Nothin' but drums on all 4 corners! past horses in the stable 72 C10-short step (97-02), 68 C10-long fleet (06-12) |
