Old 12-29-2007, 04:51 PM   #1
72chevyman
72 chevy needs to get lower
Front it has 1 coil cut. The rear has a 4" drop coil. I had 2.5" drop spindles but took them back because the tie rod ends were wrong.
I was thinking to get :
2.5" drop spindles
6" drop coils(rear),
4 shocks
What brand is better or where did you buy parts from??
72chevyman is offline   Reply With Quote
Old 12-29-2007, 07:17 PM   #2
st1x10
st1x10's Avatar
Re: 72 chevy needs to get lower
Early classic. I got all the rear suspension from them and will soon be ordering my drop spindle from them. I have the super track bar, 6" springs and the shock relocators. For shocks I got some from my local parts store. It rides so much nicer with good shocks on all 4 corners.
earlyclassic.com
1970 Chevy C10 "Under Construction"
2002 Chevy S10 V6
st1x10 is offline   Reply With Quote
Old 12-30-2007, 06:35 PM   #3
Zander478
Zander478's Avatar
Early Classic. I have wasted so much money trying many different company's components. In the end, I wish I would have started with them.
Zander478 is offline   Reply With Quote
Old 12-30-2007, 08:22 PM   #4
72BlckButy
Tot Roddin'
72BlckButy's Avatar
They are the way to go... I'm planning on picking up their 4/6 kit hopefully sometime this year. Good luck with the suspension upgrade...
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 12-30-2007, 08:39 PM   #5
Ben IV
i have used parts from both ece and maghuys and like both. If you need to change balljoints anyways you can get 3" drop spindles from djm or belltech and use 72-87 balljoints and tie rod ends.
70 GMC custom short bed conversion
69 GMC panel truck
Ben IV is offline   Reply With Quote
Old 01-15-2008, 03:37 PM   #6
chevydog66
GM ONLY BABY!!!
chevydog66's Avatar
or try CPP www.classicperform.com
2 wrongs don't make a right, but 3 lefts do.
66 Chevelle Malibu 406ci, 573hp, 10.99@121mph
96 Chevy Silverado Z71
72 GMC 1500 Super Custom LS 6.0/4L65 on airride
http://www.cardomain.com/ride/707879...mc-c-k-pick-up
chevydog66 is offline   Reply With Quote
