View Poll Results: Best Drop Shock? | |||
Toxic | 1 | 5.00% | |
Edelbrock IAS | 0 | 0% | |
DJM Cal Max | 1 | 5.00% | |
Bell Tech Nitro Active | 5 | 25.00% | |
Doetsch | 2 | 10.00% | |
KYB | 3 | 15.00% | |
Bilstein | 4 | 20.00% | |
Koni | 0 | 0% | |
"Other" | 4 | 20.00% | |
Voters: 20. You may not vote on this poll |
12-29-2007, 08:13 PM | #1 |
______________
Best Drop Shock?
I need a set of shocks for a 5/7" drop and am trying to decide between the following:
1. Toxic 2. Edelbrock IAS 3. DJM Cal Max 4. Bell Tech Nitro Active 5. Doetsch 6. KYB 7. Bilstein 8. Koni 9. Other If you chose "other" - please let me know which shock you've had success with. |
12-30-2007, 02:16 PM | #2 |
67-72 Addict!
Re: Best Drop Shock?
My dad went with KYB GR-2's for a soft ride. I went with KYB Gas Adjust's for a firmer ride and more control. I love them!
Jim 1970 C/10 Fleetside w/Ghost Flames Lowered 4.5" front and 4" rear (Raked) 355/350 Turbo w/shift kit 10" Redneck Performance Verter w/2500 stall Hooker Super Comps part#2808-1 Performer RPM Air-Gap 12 Bolt w/3:73 gears- Eaton Posi Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads |
12-30-2007, 02:39 PM | #3 |
______________
No one is running Toxic's?!
3 votes for KYB so far... |
12-30-2007, 03:30 PM | #4 |
I have the belltechs on my s10 if that counts.
1970 Chevy C10 "Under Construction" 2002 Chevy S10 V6 |
12-30-2007, 06:28 PM | #5 |
BellTech hands down. I have tried several brands on my '70 stepside with a 4.5-7 Early Classic drop, and I will never use anything else. Ride quality and handling are outstanding. Hope this helps.
12-30-2007, 06:52 PM | #6 |
______________
12-31-2007, 01:56 AM | #7 |
It Is What It Is,,,,
Im sitting on the DJM CalMAx shocks,,,, Dont really know if I like them. I just feel that there might be a better shock out there, Ive heard killer things about Bell Tech Nitro Active & Doetsch's.
When ever I get extra cash Ill change to one of those.
*79 C10 Short Box ST8 6 bang'r * *Lowered w/ 3" Control arms, 2" Lower Coils and 4" shackles and hangers W/ FLIP KIT *__--__* 79 C-10 project* .........................__ ..............._____ l __\___ ..............|_(O)_ |___(O) ] FAQ INDEX Thread The Kulture My Rat Den |
12-31-2007, 02:23 AM | #8 |
I run Toxic Shocks on my '93 but I can't really tell much as they don't have a whole lot of miles on them yet. They do seem sorta stiff. Next set, I may go for Bilsteins. They are a proven shock and have never heard anything negative about them.
'93 Silverado Reg. Cab Shortbox .060 over 350 Quick and fun!!! |
12-31-2007, 10:14 AM | #9 |
I'm still running nitro actives up front from when i had a 5/7 drop from 6 years ago. Rides great.
Mexican |
12-31-2007, 01:33 PM | #10 |
67-72 parts collector,…
I took brand new Toxic shocks off my old '99 (4/6 drop) and installed Doetsch. No comparison. I wouldn't use Toxic shocks if they were free. Plus you usually have to assemble some part of them. (lower mount). Otherwise I use Belltech. My blazer has KYB's from ECE. Nice shock,... but you can get them cheaper locally at the parts stores.
01-01-2008, 06:56 AM | #11 |
Like a Rock!
I've always heard Toxic's are junk. Never used them before to verify.
69 LWB Runs great - work in progress Mess with me and you mess with the whole trailer park! |
01-01-2008, 08:08 AM | #12 |
^^x2
I personally have the doestch techs. Always have heard good things about them. You wont go wrong with bilsteins either. |
01-01-2008, 03:29 PM | #13 |
Señor Member
Unfortunately, this question is similar to "how big is a hole?" Well... it depends.
For my '69 Wallet Eater, which doesn't carry much more than my fat self, and rolls down reasonable roads at reasonable speeds, I've been quite satisfied with Monroe/Gabriel stockers. However, for my 2 door 2WD Tahoe, that has tons of glass and crap up high (such that it corners like a station wagon), I moved the stock mounts (and a lot of other things) and installed Rancho RS9000x series with the adjusters turned all the way up. Fronts on the 'Ho are DT's (replaced Toxics, which were lacking).
01-01-2008, 04:11 PM | #14 | |
______________
Thank you everyone! |
01-04-2008, 06:56 AM | #15 |
______________
Get out there and VOTE!
01-06-2008, 04:45 PM | #16 |
______________
Rock the vote.
