Gear Select Off Center
My gear select is off center to the left. The P.O. had the steering box rebuilt. Is there a way to adjust back to center?
Re: Gear Select Off Center
loosen the steering column mounts and reposition the column
Ok, Guess it's time to warm up the garage this weekend!!!
![]() Join Date: Jan 2007
Not to threadjack here...but.
I have to do this as well - just drove my project to work today (maiden voyage)... ![]() How far can you reposition (turn) the column before it has issues? mine is a bit wobbly as well (gear selector lever on column) - any way to tighten that up as well while I am doing this? Thanks! |
cdowns
Steering column mounts? The one that hooks to the dash inside? I suppose I need to remove the upper linkage from the trans to the column, adjust the threads and re attach? |
lks
My shifter is a little loose also, I think it's the pin attachment where it goes into the column is sloppy. Not sure how to fix that unless I get a new housing? Last edited by aventur1; 12-31-2007 at 05:04 AM. Reason: spelling |
theres also thec mount on the firewall that needs to be loosened to rotate the column//yes you may need a slight adjustment on the limnkage where it connects to the column lever
Thanks for the help!
