gas tank questions
i am putting a keg in the bed of my 69 to use as my gas tank. My questions are:
1. Can i just use a vented gas cap or do i need to run a vent hose from the top of the tank down below the bed? 2. What size bung do i need to supply fuel to my carb? What is typical, i dont have the engine yet. Thanks mark |
Fabricate till you "puke"
Re: gas tank questions
You can vent the cap, & it will work fine(did that on a keg on the back of a frame car). As far as line sizing, 3/8" will work on a fairly warm small block, or mild bigblock.....crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
