Old 12-30-2007, 08:50 AM   #1
xtreme80
Wishin' I had more money!
xtreme80's Avatar
Talking New Parts!!!
Thanks to gchemist I have some new parts waiting to go on my truck!
Too bad I have no idea how to put together these new plug wires I got.
Can anybody explain this? Or point me in the direction of some help?
xtreme80 is offline   Reply With Quote
Old 12-30-2007, 09:25 AM   #2
68GMC454
THE VILLIAGE IDIOT
68GMC454's Avatar
Re: New Parts!!!
there is a toool you buy that will help you put the wires together..i froget what it is called, havent done that kind of wires in years....
honestly honey,,i have no idea how that truck got here.
68GMC454 is offline   Reply With Quote
Old 12-30-2007, 10:44 AM   #3
xtreme80
xtreme80's Avatar
Re: New Parts!!!
The kit comes with little crimpers that are supposed to go in a vise, but I don't have a vice, and that looks ghetto anyways. I think I can make something work, since I found instructions online...
Old 12-30-2007, 12:28 PM   #4
Pyrotechnic
Pyrotechnic's Avatar
Re: New Parts!!!
Are you running manifolds or headers ? I haven't seen a header design for these trucks that straight boots worked for. Seems straight boot plugs are more suited to big blocks.
Pyrotechnic is offline   Reply With Quote
Old 12-30-2007, 12:49 PM   #5
xtreme80
xtreme80's Avatar
Re: New Parts!!!
Stock manifolds lol... I checked before I got them from gchemist
Old 12-30-2007, 08:51 PM   #6
BowTieOgre
Re: New Parts!!!
I put a set like that on my '73 Blazer and it ran like a champ afterwards. I didnt have any special tools but they would have helped. Lay the wires out like they will be routed from the dist to the plugs, mark and label them and decide if you need straight or 90 ends. I just took my wifes kitchen shears (shhhh) and cut about 3/4" of the red sleeve and white insulation off, then I folded the wire over the side of the sleeve and crimp on the appropriate connector. I had to coax the plug end of the connector thru the 90 boot with some dielectric grease (included in my set). I just ordered a set of wires for my '80 so one of us should have a pictorial soon eh?
1986 C10 - LWB, 305/700r4, posi, vortec heads
BowTieOgre is offline   Reply With Quote
Old 12-31-2007, 05:38 AM   #7
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
Re: New Parts!!!
Which way are you going to run them? Over the cover, along them or under the manifolds? A wire loom setup would match nicely.
Gerardo a.k.a. Mad Chemist
Silverado XST videos
gchemist is offline   Reply With Quote
Old 01-01-2008, 10:02 AM   #8
chev74
Addicted to Chevy
chev74's Avatar
Re: New Parts!!!
i would try and run them from the back on the engine, down, and out from around the back. it cleans it up a lot and makes them less visable. and moroso makes some nice wire loom holders for this setup to boot - no pun intended
chev74 is offline   Reply With Quote
Old 01-01-2008, 02:46 PM   #9
Restrorob
The One And Only !!!
Restrorob's Avatar
Re: New Parts!!!
Most wire crimper's as the below style have the plug wire crimper as well, I used one like this for many years, It will roll the two flaps around the wire like factory.
93 Jeep XJ
88 Buick La Sabra
Toys;
88 TA-GTA in the works....
97 GMC Ext. Cab
Old 01-01-2008, 07:25 PM   #10
xtreme80
xtreme80's Avatar
Re: New Parts!!!
I have 3 different sets of crimpers, and one has these on it, and actually says "Plug Wire" on it haha... and I just tried it, cuz it gives like 5 extra crimp ends, and it works beautifully!
Thanks man!
And Gerardo, I'm gonna try running them over/along the side of the valve covers. We'll see how it turns out tomorrow I guess!
Old 01-01-2008, 11:00 PM   #11
gchemist
gchemist's Avatar
Re: New Parts!!!
Did you cut them to length?
Old 01-02-2008, 07:04 AM   #12
xtreme80
xtreme80's Avatar
Re: New Parts!!!
I haven't even started yet man. Haha, by the time you read this though I should be done.
And yes, they will get cut to length. I took the shortest one and crimped one on just as a test. It should be the correct length for one of them anyways, but if not I will cut it to fit.
Old 01-03-2008, 09:13 AM   #13
xtreme80
xtreme80's Avatar
Re: New Parts!!!
Update: Parts are on, and I know you all love pictures, so here ya go!
I put on new cap and rotor(msd), new plug wires(accel), new plugs(delco), and the chrome valve covers.
The one thing I noticed after installing these, is my idle in gear dropped from about 550 to about 400. Not sure why, but that's what I noticed.
Any ideas?
Old 01-03-2008, 02:44 PM   #14
gchemist
gchemist's Avatar
Re: New Parts!!!
Ditch the air cleaner!! It's too small. You need at least 4" or more. The engine will run cooler too.
Nice install. Install some holding wire looms for looks.
Old 01-03-2008, 02:57 PM   #15
piecesparts
Parts and more parts
piecesparts's Avatar
Re: New Parts!!!
Keep the air cleaner covers and purchase a 4" filter (either a paper one or a K&N item) and install it in between the chrome parts. I have run a 4" filter in most of my trucks for years and the higher element allows for a smoother air flow across the lower filter plate and works to make the carb more efficient.
piecesparts is offline   Reply With Quote
Old 01-03-2008, 03:05 PM   #16
gchemist
gchemist's Avatar
Re: New Parts!!!
I recommend a 4.5" K&N for open element filters.
Old 01-03-2008, 07:28 PM   #17
xtreme80
xtreme80's Avatar
Re: New Parts!!!
Hmm... I'll have to invest in one of those I guess. I knew that on a carbbed motor, the air cleaner can make a world of difference, I guess I just didn't realize how much difference.
