Old 12-30-2007, 10:26 AM   #1
Pugz_NC
Bag ? from a newbie.....
I have a 70 c10 i am in the process of bagging.Question is i have 2.5'' drop spindles, plate bracket setup in front from ***************** and have cut the lower cups down to1.5'".I am running a set of 15x8 ralleys with 255-60-15 tires with 2.5" whitewalls (26 inch tall tire) ,Will the front lay on this or abour how far will it be from laying in the front?Also i am running a Kp step notch in rear with factory trailing arms with all stock crossmembers.Thanks in advance.......
Pugz_NC is offline   Reply With Quote
Old 12-30-2007, 10:56 AM   #2
gringoloco
A guy with a truck
gringoloco's Avatar
Re: Bag ? from a newbie.....
You should have no problem laying the control arms on the ground with that setup, with the exception of inner fender/tire clearance.
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is online now   Reply With Quote
Old 12-30-2007, 03:37 PM   #3
PrerunnerRob
PrerunnerRob's Avatar
The first things that get in the way are the front crossmember, and the trailing arm crossmember. If you want to lay down to the rest of the frame, it is quite a bit more involved, but not impossible.
PrerunnerRob is offline   Reply With Quote
