Old 12-30-2007, 02:17 PM   #1
bdydrp97s10
bdydrp97s10's Avatar
73 crossmember in 68???
how hard is it to take the entire front crossmemer from a 73 with disk brakes and put it in a 68.. how does the steering linkage fit up..
what all needs to be changed??
bdydrp97s10 is offline   Reply With Quote
Old 12-30-2007, 03:33 PM   #2
extd56
extd56's Avatar
Re: 73 crossmember in 68???
It will all bolt up with no problems. You will have to drill 2 new holes for the crossmember but otherwise a very easy project. I did it on a 67 CHevy frame using a 79 subframe.
extd56 is offline   Reply With Quote
Old 12-30-2007, 03:39 PM   #3
bdydrp97s10
no steering linkage modifications???
Old 12-30-2007, 03:41 PM   #4
extd56
extd56's Avatar
no, just some drilling and go.
Old 12-30-2007, 06:01 PM   #5
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
The only thing I would add is to use new grade 8 hardware.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 12-31-2007, 02:22 AM   #6
70GMCer
70GMCer's Avatar
I've read on here that most that do this swap, don't even use the 2 holes that don't lien up. I remember removing the front suspension from a 84 burb, and there were a lot of bolts that had to be removed. I plan on doing the same swap in the Spring.
1997 GMC Sierra Ext
1965 Mustang
70GMCer is offline   Reply With Quote
Old 12-31-2007, 01:32 PM   #7
bdydrp97s10
thank you all for your input
Old 12-31-2007, 03:22 PM   #8
67c-10Texas
works great - 85ish front member - some after market motor mounts need a hole to be drilled in the crossmember - bolt locations are different
67c-10Texas is offline   Reply With Quote
