12-30-2007, 04:04 PM | #1 |
Auto meter gauge cluster questions
I have been thinking of doing an autometer gauge cluster. My truck is an 87 with tbi350 and 700r4. Here are my questions.
1. So if I use an aftermarket speedo, will I loose my cruise control (according to SwervinErvin: they make an Autometer with the right speed sensor to get around that problem on his 86.) But I'm not carbuerated 2. And more importantly, will I lose my lockup. The speed sensor sends a signal to the computer that controls lockup in my tc, right? 3. What about the other dummy lights? What have you guys done about these problems? Thanks, Joseph |
01-01-2008, 07:38 PM | #2 |
Re: Auto meter gauge cluster questions
This isn't a stupid question is it?
01-01-2008, 08:51 PM | #3 |
i'm waiting for a response as well --- my '88 Blazer has an earlier cluster in it that i would like to throw in the lake
(it occasionally rings up a "choke on" idiot light-- but its TBI -- weird -- but all the 4wd stuff lights up right)
Are you retired too? Nonsense! I'm in my prime |
01-02-2008, 08:12 AM | #4 |
Junior Member
You may give Covan's Classis a call since they sell the complete dash packaged with autometer guages. Good Luck!
01-03-2008, 07:43 AM | #5 |
I looked on their website and they make no provision for it. It seems to be the same dash for everything 73-87. Maybe I am overthinking this.
Hasen't anybody done this for their tbi chevy? |
01-03-2008, 12:00 PM | #6 |
Garage Queen Material
i think i'm the only other one to do it like mike so far.
i followed his directions partially. once you have everything its really not that hard to figure out what needs to be done. i bought ALL electric gauges. my electric speedo had to have an autometer sending unit. that unit has a place to hook up a cruise control cable, but mine is an '86. not sure what differences there would be with your efi. and i removed ALL of my cruise control equipment. |
01-03-2008, 03:01 PM | #7 |
BAD BOW-Silverado XST
The dummy lights are easy to keep. Install led lights to the original wires. The TC is not a problem. The lockup sensor is located under the hood. It has a vacuum line conneced to it. The sensor is on the firewall near the heater box.
Call Autometer on the cruise. You do lose cruise control if you install a mechanical speedo. The factory speedo uses an optical sensor plugged into the rear of the stock speed. A mechnical signal generator can be installed. I removed the stock cruise for an aftermarket cruise. I used a Rostra unit. A lot of hot rodders use Rostra units. http://www.rostra.com/cruise-control.htm The 87 steering column should accept the Rostra control lever. I'll be doing the Autometer guage swap too!! Pictures of installation comming too. Last edited by gchemist; 01-03-2008 at 03:02 PM. |
01-03-2008, 03:14 PM | #8 |
Always a work in progress
ocbaud,
is that a stock plastic dash w/a billet cover or is it completly aftermarket? Do you have a write up or details on how you installed them? Your setup looks clean.
USMC Retired Never trust a man who can't laugh at his own fart! 2010 Silverado Crew Cab 73 SWB 5.3/4l80e Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=695168 |
01-03-2008, 04:25 PM | #9 | |
i dont have a write up, but if you follow the one at 73-87.com , its pretty much the same way. i just used lots of hot glue instead of epoxy to hold them in place. |
01-03-2008, 04:53 PM | #10 |
hey o.c looks great........if you don't mind sharing.i'm curious on cost.i know a covans is like $640 something.i betcha you came in well under that?
" Never look up a dead dogs butt." |
01-03-2008, 06:09 PM | #11 | |
4x 2 5/8" elec. gauges 1x 5" tach 1x 5" elec. speedo 1x speedo sender 1x wiring harness kit 1x new dash bezel well worth the cost though, my favorite mod so far |
01-03-2008, 08:11 PM | #12 |
Costs for my setup from www.summitracing.com
PRF-30301 wiring harness $77.95 ATM-5154 Speedo mechanical $115.95 ATM-5160 Tach $124.95 ATM-5415 Fuel $39.95 ATM-5492 Volt meter $39.95 ATM-5421 Oil pressure $52.95 ATM-5437 Water temp $46.95 Total: $498.62 + speedo cable cost Last edited by gchemist; 01-03-2008 at 08:11 PM. |
01-04-2008, 12:36 AM | #13 | |
yeller
A cluster like Erics or mine will run approx $600 if you buy everything new (at full price) and do it yourself...at least that is what I have in mine, including the alum panel.
Jeff 73-87.com 73-87.com Facebook page 73-87 cab corner 6x9 speaker brackets for sale 67-72 cab corner speaker brackets for sale 47-54 cab corner speaker brackets for sale |
01-04-2008, 06:57 AM | #14 |
Thanks guys all good info.
Gchemist--I sure can't find the sensor that you are talking about. Could you describe it or it's location a little better. Thanks. I know it says this is my first post, but I used to post on here a little a few years ago. I couldn't remember my name or password or my old email for that matter, so I created a new account. I often lurked and browsed here though. I always find answers and everyone is normally positive and helpful, and I belong to a few different boards in the mustang and turbo buick online community. ocbaud--Most of my friends and car buddies normally don't see what I see in my truck. They just don't get it, or can't appreciate the body style. I normally show them a picture of your truck--to help them understand. |
01-04-2008, 07:34 AM | #15 |
post up a pic of your truck if you can -- welcome to the board
01-04-2008, 08:59 AM | #16 |
This picture is from 04. It doesn't look as good anymore. Since then, I've gotten married and had a kid+was working on other projects. But now I won't be driving my truck everyday(just most of the time). And for Christmas my wife surprised me by getting my spare seat reupholstered. This has resparked my interest--besides I can't put this beautiful seat in a beat up truck, right?
01-04-2008, 10:10 AM | #17 |
[QUOTE=jdurant;2512411]Thanks guys all good info.
Gchemist--I sure can't find the sensor that you are talking about. Could you describe it or it's location a little better. Thanks. [QUOTE] The lockup sensor or speedo? The lockup is pictured here. Top right corner above the red transmission oil dipstick. |
01-04-2008, 10:43 AM | #18 |
I have a sensor there, but it has no vaccuum line attached. It is all electronic.
01-04-2008, 12:09 PM | #19 |
www.73-87chevytrucks.com
You will need the Electronic speedo to keep the cruise, If you call Autometer they will tell you what you need for the ECM, but the Speedo should send a signal you can tap into...
Chris Lucas 1973 Chevy C-10 1978 GMC Jimmy (2WD) - SOLD 1987 R10 twin turbo LS 1991 R3500 SRW CrewCab 1985 K5 diesel swapped project 1989 K5 2WD conversion w/ Vette susp Project Captkaos Customs 73-87chevytrucks.com |
01-07-2008, 12:37 AM | #20 | |
It Is What It Is,,,,
That going to be one of my add ons. Just haven't decided if I want the gauges flush like yours or with the ring showing
*79 C10 Short Box ST8 6 bang'r * *Lowered w/ 3" Control arms, 2" Lower Coils and 4" shackles and hangers W/ FLIP KIT *__--__* 79 C-10 project* .........................__ ..............._____ l __\___ ..............|_(O)_ |___(O) ] FAQ INDEX Thread The Kulture My Rat Den |
01-07-2008, 08:05 AM | #21 |
Dark Heart Motorsports
ocbaud... where did you get your hub for your steering wheel breh?~!
How Deep Can YOU Bleed..? 1985 Chevy Blazer K5- 6.2 N/A, 400 turbo trans CUCV, 12v converted... a new chapter 2005 GMC Sierra Crew Cab 6.0 powwwaa!!! custom jumpseat install w/ captain seats, Hypertech tuner, MSD Blaster Coils, CB and twin antenna's, all electric interior, touch screen in dash. custom center console, with jump seat replacing original console. 1500 HD! |
01-07-2008, 03:49 PM | #22 | |
01-08-2008, 06:17 AM | #23 | |
http://www.73-87.com/7387garage/inte...s_recessed.htm
01-08-2008, 08:06 PM | #24 |
01-08-2008, 08:08 PM | #25 |
