Head Light Mount Buckets
does any one know if the 73 chevy pickup has the same head light bucket as the 72 c/10? the reason i am asking is i cant find knew buckets for my 72. i ordered new ones from lmc, but they were for any earlier model. i called everyone i could think of and was told by all that the 72 bucket has not been reproduced yet. i called the local chevy dealer and was told they can only go back to 73. so if the 72 and the 73 are the same i can order them from the chevy dealer.
![]() It must be fought for, protected, and handed on for them to do the same.... Ronald Reagan |
![]() Join Date: Aug 2003
Re: Head Light Mount Buckets
Why do you need new ones? Are you talking about the metal part or the stainless?
i need the actual buckets the head light sits in. mine are old and the slots for the adjusting screws are weak and easy to bend, when i adjust the head lights they sometimes pop out of the slot. i thought about buying used but that may put me in the same position
#4 | |
PROJECT 7DEUCE
![]() Join Date: Dec 2002
Have you tried buying the new adjuster screws and the little plastic pieces they screw into,that fixed mine had the same problem.
GO BIG GREEN ![]() MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
#6 | |
i have just yesterday installed new adjusting screws and the plastic nut serts, along with new retaining springs. i sanded my old buckets and will paint them tomorrow. i will use them until i can get new ones.
PROJECT 7DEUCE
Seems like all 67-72 buckets would be the same except for the gmc's of course.
they are definitetly not the same, i bought new from lmc. the diff is the 72 has a slot for the retaining spring. the 67-69 has the slot cut out and there is no place for the spring to connect
