Old 12-31-2007, 01:20 PM   #1
Evans
Evans's Avatar
How to remove front 6 lug drums ???
Looks like 3 rivets holding them to the hub , do I need to grind these off or do I gotta pull the hub too ??
Evans is offline   Reply With Quote
Old 12-31-2007, 01:36 PM   #2
too much stuff
Roadtrip!
too much stuff's Avatar
Re: How to remove front 6 lug drums ???
I usually pull the hub assembly, and then grind the rivets off. Much easier to get into next time.
67 gmc custom lwb dakota truck. Sold...And bought back
69 swb 4x4 project (in progress)
70 c-10 lwb texas truck
70 4x4/BB/bkts/posi/tach(retired)
70 swb (wifes)
70 jimmy camper
71 K-5 factory 2wd
71 cheyenne 4x4/tach/posi/ plow rig
71 Cheyenne20 BB, buckets, tach, tilt, 4 speed
72 jimmy CST wyoming rig
72 jimmy Colorado rig
72 lifted texas 4x4 3/4 ton burb
65 fury conv. 383/auto
65 chrysler 300 "L" 413 auto
too much stuff is offline   Reply With Quote
Old 12-31-2007, 01:46 PM   #3
Evans
Evans's Avatar
OK , ground the rivets off while on the truck ... still can't get the drums to budge .... any tips for that ???
Old 12-31-2007, 01:48 PM   #4
kelsfine69
18 Till I Die
kelsfine69's Avatar
Its rusted together, try some heat and/or some penatating fluid and a BFH
2011 GMC Acadia
1969 GMC BBC LS7
2007 GMC Crew Duramax
1987 Camaro Iroc 350 Tuned Port Injection
42000Km
1987 Chevrolet Silverado 350 TBI
1987 Chevrolet Silverado 350 TBI(yes 2)
Take me drunk, I'm too home...
kelsfine69 is offline   Reply With Quote
Old 12-31-2007, 01:52 PM   #5
Evans
Evans's Avatar
Thanks , I'll try that tomorrow , no need for the whole house to smell like PB Blaster tonight anymore !!
Old 12-31-2007, 01:54 PM   #6
DavesRide
DavesRide's Avatar
Penetration oil plus time to let it soak in and a large hard rubber hammer. It will break loose it won't be all beat up from a metal hammer. Last resort, dead blow or sledge. On a funny note, I watched a guy inialate a rear drum for 2 hours. It came right off after released the emergency brake. True story and no names mentioned. It wasn't me either. David
R.I.P ESLL Even as the body dies the spirit lives on in the people you touched
DavesRide is offline   Reply With Quote
Old 12-31-2007, 01:56 PM   #7
too much stuff
Roadtrip!
You might have to go through the knockout and back the brakes off...
Are you sure you are ground off flush?
70 swb (wifes)
70 jimmy camper
71 K-5 factory 2wd
Old 12-31-2007, 02:08 PM   #8
kelsfine69
18 Till I Die
kelsfine69's Avatar
After you grind off the rivit heads beat them thru with a big punch. They will end up in the brakes but they will fall out after you get the drum off. I bought a 65 once and in 20 years they were still on there. Air hammer sheared the heads off, punch them thru and tapped betwwen the wheel studs to break the rust loose. If the brakes have worn a groove in the drum you will prob have to back off the shoes to pull the drums
2011 GMC Acadia
1969 GMC BBC LS7
42000Km
Old 12-31-2007, 02:32 PM   #9
Evans
Evans's Avatar
Cool , I'll soak them with PB and drive out the rivets ... see what happens ....
Old 12-31-2007, 04:31 PM   #10
passthebuck
Sisyphus was my mentor!
passthebuck's Avatar
I pulled the hub/drum together & ground thae rivits off flush at the bench grinder. I then took the drum, held it 6 inches off the ground & droped it (inside part down) until the hub dropped out. i only needed the drum for a brake job-the hub was toast anyway.
passthebuck
#5642
-TWO 1967 GMC 910's. One with L6/3-on-the tree and the other with 355 w/435hp & a 700r4.
-a 2013 Honda Civic as my "sensible" car
passthebuck is offline   Reply With Quote
