View Poll Results: Which rust preventer do you recommend?
POR-15 18 54.55%
Eastwood Rust Encapsulator 8 24.24%
Rustbullet 6 18.18%
KBS Coatings 1 3.03%
Voters: 33. You may not vote on this poll
Old 12-31-2007, 06:10 PM   #1
geoman
Rust Coatings
Hey guys,
I did a search on this one and I am still up in the air on all the rust inhibitors/encapsulators,etc. I wanted to post up a poll and see if others here have used more than one of these items and if you noticed a difference.
My main goin is to coat my floors (inside and out) and the inside of my firewall and up under the dash. I am not worried about UV sensitivity because you are not going to see it and this is my DD. I have used POR-15 and it seems to work pretty well. I have had it peel a couple of times in real small areas but it looked great! I have never used any of the others. Seems like most are about $40/quart now. eek!
Please chime in and post your favorite.
Thanks!
Mike
1967 Fleetside, Sanford and Son Special
Ivory/Blue Vinyl, 350/TH-400/12-bolt
geoman is offline   Reply With Quote
Old 12-31-2007, 06:21 PM   #2
70' GMC
HERE.......Somewhere
70' GMC's Avatar
Re: Rust Coatings
Everyone here is always talking about por 15.
Current rides: 2013 Hyundai elantra gt DD
1995 camaro my first crush lmao
Was: 1970 with a 350 4barrel and 288 horses
Classics make it possible!
70' GMC is offline   Reply With Quote
Old 01-01-2008, 05:18 AM   #3
geoman
Re: Rust Coatings
Yes, just wondering about the other products. Seems there are so many mixed reviews so I wanted to see what others say about the other products if they use them.
Old 01-01-2008, 06:08 AM   #4
Ace in the hole
Re: Rust Coatings
I am going to be giving this stuff a try- http://67-72chevytrucks.com/vboard/s...t=rust+coating
1970 K20, 350--- SOLD
05 silverado extended cab short box- duramax
Jeep wrangler unlimited
Ace in the hole is offline   Reply With Quote
Old 01-01-2008, 06:22 AM   #5
bad6772
Official Site Guitar Shredder
bad6772's Avatar
Re: Rust Coatings
i used POR 15 on my chassis and..its great stuff.....a little goes a long way........
bad6772 is offline   Reply With Quote
Old 01-01-2008, 07:05 AM   #6
Sport/Truck
Sierra Grande Club
Sport/Truck's Avatar
Re: Rust Coatings
I’ve used POR15 and Rustbullet. My vote is for Rustbullet. I would recommend you check there site out before you buy.
s/t
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe.
Sport/Truck is offline   Reply With Quote
Old 01-01-2008, 08:35 AM   #7
Re: Rust Coatings
MsGross got this stuff from a guy in NJ that left Por15 because they cut back.I`m waiting for him to hop in.
Old 01-01-2008, 09:39 AM   #8
Ace in the hole
Re: Rust Coatings
I ordered mine right from the factory- http://www.nomorerust.com/pricelist.html and it goes on real nice. A little goes a long way. I used the silver sealer with the ag111 satin black top coat (they sell it as a kit for chassis for around $65) and am really happy with the results. As for how it holds up, I'll have to let you know in a couple of years.
Last edited by Ace in the hole; 01-01-2008 at 09:44 AM. Reason: added chassis kit info
Old 01-01-2008, 09:41 AM   #9
Wrenchbender Ret
Re: Rust Coatings
I use Rustoleum Rusty metal primer. Tough stuff & levels out good.
Wrenchbender Ret is offline   Reply With Quote
Old 01-01-2008, 09:47 AM   #10
Re: Rust Coatings
I've been using Eastwood Rust Encapsulator. So far it seems real good and it doesn't require the special prep and application that POR-15 does.
Palf70Step is online now   Reply With Quote
Old 01-01-2008, 10:22 AM   #11
96blazr
96blazr's Avatar
Re: Rust Coatings
RUSTBULLET!! Hands down is THE best product for rust inhibitors, period. You can spray it on, brush it on, Sand it down and even paint over it, cause it will stop rust in it's tracks.
Do I work for them? Nope. Have I used it on my own truck? Yes.
I did a lot of research on these types of products before I bought anything and I kept noticing that POR-15 had a lot of steps just to make sure it worked correctly. I also noticed that a lot of complaints were that it "peeled" or didn't adhere to the metal or this and that. So I jumped on Rustbullets sight and bought their product. Figured it couldn't hurt and by what I read I was, and still am, Impressed.
Don't have any pics at this time but hopefully, within the next couple of weeks, I will.
*The opinions expressed are mine and mine alone.
HAPPY NEW YEAR EVERYONE!!!!
1968 SWB.
GMPP 350/350 Turbo Trans, Edelbrock Performer & Carb. Hedman Hedders, Hooker Aerochambers Mufflers. Tuff Stuff Alternators.
Remember, no matter where you go,
There you are.
Gary
96blazr is offline   Reply With Quote
Old 01-01-2008, 04:29 PM   #12
Sport/Truck
Sierra Grande Club
Re: Rust Coatings
I followed your link, but when I clicked on product info it loaded a blank page. I hit the refresh and nothing…..
s/t
Old 01-01-2008, 05:34 PM   #13
Ace in the hole
Re: Rust Coatings
that's odd, not sure what's going on with it. try it from the home page- http://www.nomorerust.com/
Old 01-01-2008, 06:05 PM   #14
Sport/Truck
Sierra Grande Club
Re: Rust Coatings
Thanks, that's working.
s/t
Old 01-01-2008, 06:08 PM   #15
low burb
Re: Rust Coatings
You might want to look at Zerorust, too. Autobodystore.com did some testing against POR-15 and Zerorust protected better in his tests.
http://www.autobodystore.com/new_page_1.htm
Michael
1971 GMC Suburban "Crusty"
2000 GMC Sierra 1500 2wd
1978 Scout II
1992 Passat Syncro
low burb is offline   Reply With Quote
Old 01-02-2008, 06:05 AM   #16
stope4
Re: Rust Coatings
No matter what you use, there's going to be some prep work. Don't think you can just buy the stuff and spray it over loose rust, dirt or grease and expect it to adhere correctly. All the products are some type encapsulator that prevents air from reaching the metal. For this to work, the coating has to be pretty tough. I'd say it all works good if your prep is adequate. I prefer POR-15 because I can beat it with a hammer and it doesn't come off. I've never had it peel and I have used a bunch of it on brackets, firewalls, frames, an underbody, marine applicatios on boat slips, rims, etc... But I still bet they all work because they are all chasing POR-15, and, it works!
stope4 is offline   Reply With Quote
Old 01-02-2008, 11:40 AM   #17
dastuck
dastuck's Avatar
Re: Rust Coatings
My choice is for rust bullet. It sprays on great and smooths everything out. I sprayed my frame and front suspension components with it and am impressed with how it turned out. There are pics in my build thread.
dastuck is offline   Reply With Quote
