Old 12-31-2007, 07:07 PM   #1
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Hey you, yes you!
I need some help here people where did you guys mount your tranny dipsticks. I know most of you guys more than likely mounted them on the firewall bu I bought a lokar unit to match the rest of my stuff and I smoothed out the fire wall and I just cannot bring myself to drill holes in the fresh shave job. Any help or pics or maybe some sweet ideas you have had in your head would be great. Thanks Luke.
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 12-31-2007, 07:22 PM   #2
72cheyennesuper20
72cheyennesuper20's Avatar
Re: Hey you, yes you!
Drill holes in your firewall (Did I just say that). I did it on a Chevelle I had with a Lokar dipstick. Once you drill them you will forget about it. If not they are easy to weld up.
72cheyennesuper20 is offline   Reply With Quote
Old 12-31-2007, 07:23 PM   #3
stllookn
Saving 1 truck at a time!
stllookn's Avatar
Lance...what did I miss? Mine mounts to the bolt in the bell housing...TH400 and TH350.
'68 C20 Longhorn 50th Anniversary 400/TH400
'68 C20 Longhorn 50th Anniversary 468/TH400w/buckets
'72 C20 Halfhorn (Longhorn w/o cab and front clip)
'69 Flxible Cruiser (look up ugly in the dictionary)
stllookn is offline   Reply With Quote
Old 12-31-2007, 07:28 PM   #4
FRENCHBLUE72
PROJECT 7DEUCE
You must have the shorter model I just found those on summits site I may have to order one ...
MEMBER #6377
Project "7DEUCE"
Old 12-31-2007, 07:37 PM   #5
72cheyennesuper20
I guess I missed it also.
Old 12-31-2007, 07:49 PM   #6
hvychve
To The Levy
hvychve's Avatar
I will be following this thread, because I would like to know what dipstick of what sort is mounted through firewall:????
hvychve is offline   Reply With Quote
Old 12-31-2007, 08:06 PM   #7
stllookn
stllookn's Avatar
My '67 had the V-8 in the I-6 slot and was therefore pushed back against the firewall. None of the aftermarket fill tubes would clear. I had to go back to stock (short and close into the block) which I now prefer.
Old 12-31-2007, 08:10 PM   #8
Ben IV
You could make some kind of bracket to mount it to your back header bolt like some of their engine dip sticks.
70 GMC custom short bed conversion
69 GMC panel truck
Ben IV is offline   Reply With Quote
Old 12-31-2007, 08:27 PM   #9
Shane
Shane's Avatar
I smoothed my firewall ... and then drilled holes for the Lokar tranny dipstick ... I know how ya feel, 'bout made me sick to do it.
Shane is offline   Reply With Quote
Old 12-31-2007, 09:11 PM   #10
FRENCHBLUE72
PROJECT 7DEUCE
shane you got a pic? Maybe I could mount it down by the cab brace and flat black -it so it will dissapear.
MEMBER #6377
Project "7DEUCE"
Old 01-01-2008, 03:41 AM   #11
dfosh
Locar has them for both mounting firewall and the block .call them if you have the firewall mount i am sure they will exchange it . they are good to deal with . if you have a catalog it should show both.
dfosh is offline   Reply With Quote
Old 01-01-2008, 04:14 AM   #12
FRENCHBLUE72
PROJECT 7DEUCE
Thanks guys I m just gonna order the short one and put the longer version on my blazer.
MEMBER #6377
Project "7DEUCE"
Old 01-01-2008, 10:21 AM   #13
Shane
Shane's Avatar
No pics but I will get you one next time I go over to the shop. I mounted mine down low, right above the brace.
Old 01-01-2008, 10:55 AM   #14
FRENCHBLUE72
PROJECT 7DEUCE
Thanks shane.
MEMBER #6377
Project "7DEUCE"
Old 01-02-2008, 03:41 AM   #15
Jim_PA
I mounted mine in the trash can.
Jim_PA is offline   Reply With Quote
