Old 12-31-2007, 07:19 PM   #1
clemson71guy
clemson71guy's Avatar
fan and fan clutch
i purchased a fan and fan clutch from flex-a-lite and as usual it dosent fit.
not only that but my water pump is a reverse rotation and the chevy dealer cant even find anything that would fit it exept a 14 inch fan off of a s-10.
im kinda confused on this one
does anyone on here have a reverse rotation water pump and if so what fan clutch did you use.
clemson71guy is offline   Reply With Quote
Old 01-01-2008, 02:49 AM   #2
68C15
blood type; Retumbo
68C15's Avatar
Re: fan and fan clutch
look it up under a 90 or 91 suburban (R or V body) with a 5.7. I just did and engine in one last week and it looks like it may fit. they are reverse rotation.
68C15 is offline   Reply With Quote
Old 01-01-2008, 03:25 AM   #3
haysonj
haysonj's Avatar
My pump is off a 1990 corvette it is reverse rotation but I' not sure they had a clutch, may have had electric fans as I do.
69 Chevy 4x4 383 Power
haysonj is offline   Reply With Quote
Old 01-01-2008, 07:17 AM   #4
Shyguy
Junior Member
Shyguy's Avatar
My '92 GMC has a reverse rotating water pump with a fan clutch and serpentine belt, it has a 454 engine.
Newer 350's with the serpentine belts may have reverse rotating water pumps.
Danny-Southeast Missouri
Shyguy is offline   Reply With Quote
Old 01-01-2008, 07:47 AM   #5
KFreddy
Active Member
KFreddy's Avatar
I have a 19" reverse rotation flex-a-lite fan on my truck it fits fine with the factory shroud. Why are you using a 14" fan? I believe that flex-a-lite's smallest reverse rotation fan is 15" it is part number flx-5915. I have a spare 19" fan # flx-5919 it's yours for a few buck if you can use it. I believe that any good Thermal Fan Clutch will work in standard or reverse rotation.
"The Great State of Florida"
KFreddy is offline   Reply With Quote
Old 01-01-2008, 07:53 AM   #6
Arad68
Trucks N Tranzams
Arad68's Avatar
Reverse rotation fans and fan clutches are available from CSK auto parts. Try their website and look up 1991 Chevy 1500 pick up. Here is a link.
http://www.partsamerica.com/PartType...g&pgid=HEATAMS
Don
'68 Chevy LB 383 TH400/GV/373 posi
'56 Chevy 4WD SWB
'64 Chevy short stepside
'79 Trans Am 455/TH2004R/12blt/4whldisc
95 Kia (Wifes car)
2002 S-10 extended cab pickup
"God punishes small sins immediately"
Arad68 is offline   Reply With Quote
Old 01-01-2008, 08:00 AM   #7
clemson71guy
thanks for all the info
im not using a 14" fan thats just what the chevy dealer said he could get
