Old 12-31-2007, 07:29 PM   #1
streetstar
streetstar's Avatar
TBI problem
having a tbi prob with my Blazer, but i know this could be an issue with any tbi truck.
When its cold, it hesitates and almost dies when i hit the throttle from a dead stop (WFO, not a gradual opening) but if i travel 100 ft and then nail the throttle , it goes like stink.
it also takes 3-5 minutes to warm up to this performance level, but i have to drive it for 30 minutes it seems before it starts working optimally
Let me know any ideas possible before i R&R everything electrical under the hood. Its not a daily driver - so no a dire emergency or anything
(a running joke among a couple of mechanics i know is that anytime they take in an aviation guy's truck for repair, its bound to have new wires, plugs, dizzy cap, alternator, batt. or starter -------- people will sometimes try anything before they have to face the truth)
Are you retired too?
Nonsense! I'm in my prime
streetstar is offline   Reply With Quote
Old 12-31-2007, 09:10 PM   #2
89 crew
Re: TBI problem
check the injector spray. my 89 350 tbi had that problem. a simple dose of injector cleaner over the next couple tank fulls cured it. but my injectors were not spraying right.you should look for a pretty cone spraying down from the injectors. if it isn't right or they are not the same then I would say that is your problem.
89 crew is offline   Reply With Quote
Old 01-01-2008, 01:05 PM   #3
BLE 'BURBAN
In the Forgotten far North.
BLE 'BURBAN's Avatar
Re: TBI problem
An easy way to light up your tbi spray pattern is to hook up a timing light and point it at the tbi unit while the engines running. The strobe effect will help you to see any fluxuations in the spray pattern
1987 R3500 CREW CAB DUALLY (BIG RED)Acquired 06/12/2015
1990 chevy suburban V2500 5.7L
My cluster Mods-Nov 2007
overhead console Stereo install Round 2 Aug 2009
Heated/turn signal mirror upgrade
BLE 'BURBAN is offline   Reply With Quote
Old 01-01-2008, 08:53 PM   #4
streetstar
streetstar's Avatar
Re: TBI problem
Should i be playing "Dark Side of the Moon" in the background with the Wizard of Oz on tv?
Kidding --- thx all for the advice ------- now back to my Pink Floyd jam session
Old 01-23-2008, 03:23 AM   #5
tylerdurden
Talking Ckeck two other things
If you had a way to read data you check out the coolant temp sensor(intake manifold), not the temp gauge (driver side cylinder head). Check the idle air control valve (IAC) to see if the cone is carbon up or sitting crooked.
tylerdurden is offline   Reply With Quote
