The Original HotRod KnifeMaker
![]() Join Date: Jan 2007
Drop body, NOT suspension?
Is there a cost-effective way to drop the body front and rear without causing the exhaust system to drop with it?
Dave 69 GMC SWB 2WD 454 Turbo 400 |
Happy to be here
![]() Join Date: Mar 2000
Re: Drop body, NOT suspension?
If you are having to ask, it doesn't sound like you have the ability to do all the work yourself. If you have to have someone do the work, then cost efficiency on a body drop wouldn't be my priority.
Did you build a stainless exhaust and now want it lower? Sounds like your going to spend a dime to save a nickle.
Already made the adjustments I needed, just curious about an option I may have missed. Sounds like it wasn't a very good option.
and a few others
you may want to check this thread out. I just looked and the pictures are gone, but maybe you could contact him and get the pics.
http://www.67-72chevytrucks.com/vboa...d.php?t=256974 ![]()
Bill ![]() BlueRidgeMuscleCars.com “The greatness of a nation and its moral progress can be judged by the way its animals are treated” Gandhi |
Señor Member
Actually, a body drop isn't going to affect your exhaust height since it's not part of your body.
Fabricate till you "puke"
You will need to drop the tail pipes, to go under the rear bumper.......or, run the pipes right through the bumper
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
