Old 01-01-2008, 06:12 AM   #1
NEVERENOUGH
NEVERENOUGH's Avatar
headlight connection
Ok so we are finishing up my son's blazer and are having a problem with the headlight connections. They don't seem to want to stay connected does anybody have a solution? Thanks for your help.
NEVERENOUGH is offline   Reply With Quote
Old 01-01-2008, 08:45 AM   #2
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: headlight conection
Be more specific about the year please. Are you using the factory headlight harness? The plugs should stay pretty tight.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 01-01-2008, 09:25 AM   #3
NEVERENOUGH
It is a 1975 and it is the factory harness. When I parked the blazer 6 years ago it was like this.The are not tight at all they will simply fall off.
Old 01-01-2008, 06:25 PM   #4
N2TRUX
Happy to be here
N2TRUX's Avatar
That's odd. Look at the connectors. I can't remember if the locking tab is exposed or on the inside. With a metal pick you should be able to pull the tabs out of the connectors. With the contact tab out you can spread them to apply more tension.
I think the entire connectors can be bought new if that doesn't help.
Articles-
"Refining Sierra"
Old 01-02-2008, 04:55 AM   #5
NEVERENOUGH
Re: headlight connection
Cool thanks headed back to the garage again today so I will check it out thanks alot.
