Old 01-01-2008, 12:42 PM   #1
Chevy1TonFun
Grease Monkey
Chevy1TonFun's Avatar
Eaton vs. 14 Bolt vs. Dana 60
I have an Eaton rear end with RJ H02002 stamped on the third member. What ever that means I not sure. I don't know much about Eaton. Since buying and building this truck I asked all the offroad shops and nobody knew what it was and had never seen it before. It wasn't until I showed Jeff at ECE that I found out what it was. He also told me that they are hard to find parts for and to get rid of it.
But lately I've been told that an Eaton is strong rear end and to keep it. I would like to get a different rear end with gears and a locker. I'm looking at a 3/4 Dana 60 or 3/4 14 Bolt. What should I do.... I need some input.
Tow Rig: 2012 Chevy 2500HD CCSB LTZ Z71 4x4 Duramax
Ultimate Offroad Build: 1978 Chevy Silverado K30 Crewcab Build Link http://67-72chevytrucks.com/vboard/s...d.php?t=654053
Mud Truck: 1972 Chevy Cheyenne K30 4x4, 468/400/205, D60/D70HD, 18" Custom Lift, 17x39" IROKs
FOR SALE http://67-72chevytrucks.com/vboard/c...ton-4x4&cat=12
Chevy1TonFun is offline   Reply With Quote
Old 01-01-2008, 01:02 PM   #2
1969k10stepside
Re: Eaton vs. 14 Bolt vs. Dana 60
I'd keep the Eaton..They are tough as nails (Tougher than the 14 bolt)..A 14 bolt is cheap and easy to get parts for but I'd stay with the Eaton unless it breaks (Doubt it will) and is cheaper to replace with a 14 bolt with a good locker.I'd look for a No Spin for it and call it done.I *think* you can use 14 bolt axle shafts,and other stuff in them too,so if you are looking to get stronger custom axle shafts,etc you could get some for a 14 bolt (If you can't for the Eaton) and use them in the Eaton.Maybe I just dreamed it but thought I read that somewhere..You get more ground clearance with the Eaton too.
1969k10stepside is offline   Reply With Quote
Old 01-01-2008, 02:52 PM   #3
62 short step
62 short step's Avatar
I'd keep it till it breaks, if that ever happens.
62 short step is offline   Reply With Quote
Old 01-02-2008, 07:56 AM   #4
Hoods69BadBowTie
Chevys Kick A$$
Hoods69BadBowTie's Avatar
I vote to keep it because I also doubt that it will ever break. Then go with a good 14 bolt if you ever need to.
*HOODS is what I answer too*
-'79, '77, '88 Pickup Sold, '85 Camaro, '83 T/A, '81,'83,'90 K5 Blazer All Sold
-'79 3/4 ton "Big Yellow Bananna" Lifted 4spd. 39.5 TSL Swampers, The money Pit
-'86 K5 Blazer Silverado 6.2 4" lift 35"s
-'95 Ext. Cab Shorty 4" Tuff Country rolling 35" M/T's
-'83 Monte Carlo T-Tops. 126,500 Original Miles
-LATER
I would rather push a Chevy then drive a ford!!
Hoods69BadBowTie is offline   Reply With Quote
Old 01-02-2008, 01:05 PM   #5
1969 GMC
1969 GMC's Avatar
14 bolt or Eaton are roughly equal in strength, I think either one of those would be good for you.
I would avoid a FF D60 rear simply because any aftermarket traction aide is going to be more costly, not to mention the other two axles are a bit beefier than the D60 (bigger pinion, ring gear, axle shafts, bearings).
I personally have an Eaton that is under my GMC, not original though. It has 5.13 gears and a factory No-Spin. My only problem with it was that it wasn't wide enough (65" wms) and I couldn't find any wider rear axles locally, so I have ordered a set of wheel spacers for the rear.
1969 GMC K2500
1996 Honda Accord
2007 Kawasaki KLR 650
1969 GMC is offline   Reply With Quote
Old 01-02-2008, 01:24 PM   #6
msgross
msgross's Avatar
I think that most people "ASSUME" that one is weaker than the other and so on.... but really haven't ever broken one. Unless you're into hard core wheelin then I can't see many axles breaking at all....
If it works for you then I'd run it till it breaks, if it breaks... If your looking at a costly rebuild then something with more parts availability would be a wise choice.
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
Old 01-03-2008, 09:35 AM   #7
Plumbnutz
Plumbnutz's Avatar
It is my understanding that 14 bolt axles and gear sets can be used in an Eaton but I have no text to back up that statement just what I've heard from others. I believe the reason they say the Eaton is stronger is because it's a solid cast diff, no axle tubes. You don't have to worry about the heat as much when welding brackets or spring perches versus a diff. with axle tubes.
74 K5 Blazer-built 350ci,Turbo 350, NP 205
8 lug Dana 44, GM Corp 14 bolt-4.56 gears, 37" Boggers
89 K5 Blazer-TBI 350, 700r4, NP 208
8 lug Dana 44, GM Corp 14 bolt-4.10 gears, 33" Toyo A/T
Plumbnutz is offline   Reply With Quote
Old 01-04-2008, 05:12 AM   #8
pumpkin
pumpkin's Avatar
I prefer the eaton, and with a bit of trimming you get 1/2 an inch more ground clearance than a 12 bolt
pumpkin is offline   Reply With Quote
Old 01-04-2008, 01:07 PM   #9
DieselEater
DieselEater's Avatar
Does anyone actually have real data regarding the similarities between the Eaton and the 14-bolt??? I have a few of each and would like to know I could share certain things here and there........where would you guys look for good data?
A.........
69' 3/4 4X4
470ci BBC
700 HP....
D60/14bolt
205/465
http://profile.myspace.com/index.cfm...ndid=127691959
DieselEater is offline   Reply With Quote
Old 01-04-2008, 01:26 PM   #10
hilbilly
I do everything twice, so what
hilbilly's Avatar
Location: To the Right. One may go as far to say WAY to the Right
A.........
You ain't using the eaton in that pull truck are ya'?
www.hilbillytruckpulling.com
hilbilly is offline   Reply With Quote
Old 01-04-2008, 01:42 PM   #11
1969k10stepside
On the rear axle subject..There is a 72 Longhorn C30 in the junkyard (For those that don't know what a Longhorn is as a truck,it's a one ton pickup with a fleetside bed with an extra 6" on it) I assume it has the HO72.The one ton's had the 72 right?Eaton Ho52 vs HO72..is there any strength difference or any plus to using one or the other?
Old 01-04-2008, 03:44 PM   #12
DieselEater
I haven't used the eaton for pulling, but know a few guys that do......None of them are making over 500 HP yet, so no real strength data on the axle yet. The 14-bolt however, has been tested thousands of times up to 1000 HP!!!!
A.......
69' 3/4 4X4
470ci BBC
700 HP....
D60/14bolt
205/465
Old 01-05-2008, 05:25 AM   #13
hilbilly
hilbilly's Avatar
1000hp?? yea, ok, only with 33" 12.50's w/ 50psi that don't hook up.
Old 01-05-2008, 11:00 AM   #14
pumpkin
pumpkin's Avatar
The best I can figure is the difference between the two is that the ho72 has a limmiting bushing that is adjustable and sits on the smooth side of the ring gear opposite the pinion to stop the ring gear from deflecting away from the pinion.
Old 01-05-2008, 11:02 AM   #15
pumpkin
pumpkin's Avatar
A.........
I know that the spiders or lockers interchange between the two. You just have to use the coresponding axles.
Old 01-05-2008, 03:43 PM   #16
DieselEater
Hey Hill billy,
Here's a great pulling site that I frequent daily.....Mostly furd guys but all are very cool.
http://www.network54.com/Forum/228279/
A........
69' 3/4 4X4
470ci BBC
700 HP....
D60/14bolt
205/465
Old 01-06-2008, 05:10 AM   #17
hilbilly
hilbilly's Avatar
Thanks, Diesel
Old 01-07-2008, 02:44 PM   #18
Old Chevy Mech
Keepin it runnin!
Old Chevy Mech's Avatar
My HO52 has that adjustable ring gear deflection rub shoe. Verified by the GM service manual and a flash light! I was suprised when I saw it. Maybe Its not an HO52 but an HO72, all I know is that it was in the K20 when I bought it. LOL
Frank
1970 K-5 4X4 Blazer
1970 K-20 4X4 Long Bed
"Liberty Means Responsibility, that is why most men dread it"
Old Chevy Mech is offline   Reply With Quote
Old 01-08-2008, 07:24 AM   #19
The difference is in the wheel bearings and brakes with the HO52 and HO72.The Corporate* rear has a lesser spline count.A 14-bolt carrier can be used with 14-bolt axles.The axles need about 3/4" (I think) cut off.
I have great service out of the original axles in my trucks,both Corporate and Dana.
*People mistakenly refer to these as Eatons.
Old 01-08-2008, 09:46 AM   #20
EFI70Blazer
Active Member
EFI70Blazer's Avatar
My buddy runs an Eaton in his Toyota Landcruiser. He has broken hubs, stub shafts, and u-joints in his front Dana 60, but has never broken anything in the Eaton. He is running 5.13 gears with Detroit lockers in both along with 44 inch tires.
On another note, you also get more ground clearance with the Eaton than a Dana 60 or a 14 bolt. Personally i would use it till it breaks. Here is a small video of him going through a mud hole.
http://vids.myspace.com/index.cfm?fu...deoid=19856624
Mike T.
Oregon
70 GMC Jimmy 4x4
70 Camaro LS1 plans in the works
71 RS/SS Camaro numbers matching
86 Chevy Silverado SWB 4x4 (454 merlin heads, 3/4 running gear upgrade, Detroit lockers front and rear)
EFI70Blazer is offline   Reply With Quote
Old 01-08-2008, 11:20 AM   #21
I got all the brake parts I needed at Napa.You can put 14-bolt disc brake set-ups on them.
Old 01-08-2008, 11:33 AM   #22
Chevy1TonFun
Grease Monkey
ok so i found a shop in utah that rebuilds 14 Bolts. He will build me one with a detroit locker and 4.56 gears for about $850. I think thats what I am going to do.
Thank you for all your input!!
Old 01-08-2008, 05:35 PM   #23
kris's66lwb
resident wrencher
so you can put 14bolt disks on the rear ho 72 or ho52s
kris's66lwb is offline   Reply With Quote
Old 01-08-2008, 06:33 PM   #24
EFI70Blazer
Active Member
Yes
Mike T.
Oregon
70 GMC Jimmy 4x4
Old 01-10-2008, 01:25 PM   #25
kris's66lwb
resident wrencher
do they just bolt up or do you have to have special stuff
