Old 01-01-2008, 01:00 PM   #1
haysonj
haysonj's Avatar
Tach problem
My tach jumps all over the place at idle when I turn on the heater or AC fan It smooths out as the RPM,s come up. I have it getting power directly from the the fuse box on a separate fuse. I was wondering if the Alt not charging at idle would have anything to do with this. Its a MSD 6A ignition and a stock Tach
69 Chevy 4x4 383 Power
haysonj is offline   Reply With Quote
Old 01-01-2008, 01:50 PM   #2
WorkinLonghorn
WorkinLonghorn's Avatar
Re: Tach problem
Mine (stock set-up) did that jumping around when the connection to the coil needed cleaning and tightening,if that helps any.
'69 GMC C2500 Custom Camper, 8 1/2' bed, New GM 350, NP 435 Close Ratio 4spd. Trans., 3.73 Dana-60 open.Camper and Trailer wiring, PS, PB, AC, tach , three gas tanks, 2nd owner, Work-Truck supreme. Best $300 I ever spent.
WorkinLonghorn is offline   Reply With Quote
Old 01-01-2008, 04:27 PM   #3
tx71smallblock
tx71smallblock's Avatar
Re: Tach problem
a good check of all conections including the fuse would not hurt
70 Chevy C-10 short step
250/3 on the tree
Owned:
71 longbed Cheyenne
70 swb
tx71smallblock is offline   Reply With Quote
